squeaky rear suspension, who has this problem?
Alright, so the past month or two, I've been tryin to figure out why my REAR PASSENGER side suspension is squeaking....it's loudest when I'm rolling the car in 1st gear, with the suspension leaning back and forth...I can also reproduce the sound by opening my trunk and pushing down on the car...it ONLY happens on the rear passenger side...here is what I've done to fix the problem..
1. Took both shocks and swapped them
2. Examined my spring isolators...they were in good condition...but I added extra insulation by wrapping the spring in electrical tape
3. Double checked the order of bushings, dust boots, etc...according to the FSM....
4. Examined the shock absorbers by pushing down on the piston...its very firm...also with the shock absorbers on the car, I can push down the car, and the car will rebound smoothly
5. Re-aligned the rear beam by using this thread http://forums.maxima.org/showthread.php?t=465329
6. Tighten all top mount nuts through the trunk
Even after with all these fixes, I am STILL getting the squeak ONLY on the REAR PASSENGER side...I was hoping that my shock absorber was the culprit...but when I swapped sides, it still made noise only on the REAR PASSENGER...another thing I noticed...I can reproduce a similiar squeaking noise everytime I jack up the REAR PASSENGER side with a jack...everytime I pump my jack to raise the car, the car gives off a squeak, until it is completely off the ground
I wanted to get everybody's input on this...cuz there was quite a few people who experience this...according to a thread a few weeks back..any input would be greatly appreciated!
Originally Posted by twitch579
mine does it over speed bumps and its only in the right rear tire area. It drives me crazy. Ive learned to live with it along with the knocking at startup. These cars sure do make some weird noises.
Originally Posted by VaporHead
Is your shock boot rubbing the springs? I think I have that problem now after installing my new springs.
I have the same problem! This happend about a year and a half ago and it has been driving me nuts ever since. I even had the nissan dealership take a look at it and they can't find a thing! all hardware is intact and safe for driving, but they can't find out what it is.
Originally Posted by Ephraim
if they are aftermarket struts, and you know your stock ones are not blown, try putting in your stock struts to determine if it still squeeks.
Don't feel to bad. I just installed my Eibachs this weekend, and my car sounds like a damn school bus. Alot of squeeks and the stock struts sound like they are blown now.
I had a squeaky front suspension and when I turned at approx. 5MPH I hear "boop boop booop" sounds. Turned out to be worn strut mounts, a call to Dave B and a trip to my mechanic solved everything.
Originally Posted by steven88
where is the noise coming from?
Also, I determined that my stock shocks are just about toast after 66k miles. I could push the piston down with relative ease, amd I correct in this assumption?
Steven88, My rear suspension had a squeaking noise at 2k miles on new springs and struts they where not worn out i sprayed deep-creep that sells on autozone solved the problem no more since then check your suspension if you push it down and it goes up without jumping then the suspension is good if not they are worn let me know go to the mechanic or inspect it your self jack up the car shake the wheel back and fourth to see good luck!
Mike
Mike
Mike
Mike
Where exactly did you spray the seafoam deep creep?
I had this problem for a while and last weekend decided to take a closer look at it. I discovered that my brake line by the strut was loose and was making the noise. I replaced the "U" shaped holder and that secured the brake line. I no longer have that noise.
But I doubt its my brake line...I didn't see anything out of place while I did my diagnosis...how exposed was yer brake line?
The noise was being made by the brake line rubbing against the bracket that secures it. The brake line had some play to it with the old holder and I had to firmly secure it with the new holder.
oh i see...how much was a new bracket?
mine does the same thing!! i always thought it was just my car. i looked at everything too and thought maybe it was the RSB. still cant figure it out. someone rode in my car today and asked why the hell my car was squeaking
Mine does too. No RSB.
are you lowered? i wonder if this is a problem with lowering springs. if you arent lowered then its something else
you know, i actually forgot to update this! I did this a few days ago by accident...well what happened was, I was messing with my suspension...and I ALWAYS hated that stupid dark metal plate that covered the rear suspension top hats....so I proceed to remove it...and when I did, wtf? that thing was barely torqued on...I thought I was crazy, so I tried to remove the drivers side rear plate...and what do you know? theres more torque resistance when loosening the bolts....AH HA!! theres my problem!!!
I haven't gotten the noise in a few days...I am positive this cured it...for anyone who has a similiar problem, give this a shot...it might help you as well
I tried that last month my self. mine was all tight. I have had all of Everythign out of my trunk for over a year. every few months I crawl in there trying new things. I am still wondering if mine is the rear seat or something.
Glad yours is fixed.
Greg
Greg
my passanger side squeaks also, ITS NOT REALLY LOUD, just annoying. If i ride in absolute silence....which generally doesnt happen, i can hear a "squeak, squeakity, squeak" TYPE NOISE and its ONLY THE rear passanger side. IM HOPING WHEN I SWAP MY SUSPENSION on monday it will resolve the issue. At first i thought it was interior but its NOT, AND IT ONLY does it when im riding over a bumpy road, it doesnt do it over speed bumps, nor when i press down on the passanger side area of the car
Huttig2009
Sep 25, 2015 03:31 PM
CAN-Other LF: Worn / Broken Parts
george__
Aug 18, 2015 07:06 PM
laparka66
Aug 6, 2015 09:36 AM
