OMG help please i am actually desperate PLEASE!
Ok. so i know there is alot of "bad gas milage threads" bu mine is a little EXTREME in the way that my car consumes 50 litters in about 115 miles!!!!!!! thats like 5 miles the galon the only thing i have done is an air fileter (K&N) but had to disconect the intake sensor. i really need help im literaly filling the car every 2 days and thats like 27$ every 2 days and thats a lot. oh and i have a 1995 maxima SE
Did you try doing a tune up? That might help. Check for any codes even if the CEL isn't on. You might have ghost codes that don't trigger the CEL. I just don't understand how you fill up for 27 bucks? You use regular? even then it shouldn't come out to 27 for a full tank.
Change Knock Sensor, being a 95 it might be due for one. also take your car to a garage and have them do an engine flush, clean the throttle body, and do a fuel system cleaning. make sure your air filter is clean... thats just the things that come off the top of my head. do all of that and if it doesnt help then you have a serious problem and need to take it to a reputable mechanic.
Hope this helps
-Colin
Hope this helps
-Colin
Thanks. by the way the CEL is on i just didnt check it because did it 3 times and got de same codes (coolant temperature sensor, and the other one dont remember) but i will try that now (even though its 1:32 in the morning). And i fil the tank up with 27$ yes i use regular and here in puerto rico is at 49.7 per gallon (in some places). so thanks and i will let you know what codes i got.
So... i cheked the ECU for the CEL and found out i only have the code 04 01 (Intake Air Temp Sensor) because i took out that sensor to put my new intake.. is this causing the milage to be so bad (BTW i am at 1/4 of the tank and only drove for 108 miles and thats awfully bad). i will go ahead and try to do what you guys told me and see if it solves anything.
i dont wanna sound like a poor fellow or something. The thing is that i didnt got it on the CEL diagnostic. and since i read that the knock sensor cost a lot (or something that people always talk about) i dont wanna go and replace it and then find out that i didnt needed it.
A leaking fuel injector would cause this too. Change your oil and if it comes out smelling like gas, STOP driving and fix the leaking injector ASAP. Gas + oil = no lubrication = spin a bearing.
i know mi milage is bad. But something that i noticed (dont know if its important) is that when i drive to any place the cars fine and as soon as i stop and park i notice a white smoke coming out of where the gasoline is supposed to be burning y dont know if its leaking and then evaporating... just to let you know and by pure coincidence when my milage became that bad thats when it started hapening
ok. coolant temp sensor will definately cause bad gas mileage. disconnected IAT will cause bad gas mileage. if your new intake has no place for a IAT, just plug it in and let it hang there in the compartment, OR drill a hole in the pipe and mount it. but dont REMOVE it. if white smoke is coming from the tail pipe, sell it or park it and fix it.
DJ
DJ
Originally Posted by ewuzh
If it's small amount of white smoke then it's probably coolant. I had MASSIVE amounts of white smoke coming out of the tail pipe when my injectors were leaking fuel. I was also getting 2mpg, but I didn't drive the car more than a few miles. If your problem is a leaking injector (o-ring seal or physical injector leak), DO NOT DRIVE ANYMORE. You need to fix that **** ASAP or you'll be in the shop swapping in a new engine real soon.
OMG i will send it to a mechanic right away to get it fix (maybe this weekend, because i cant be without the car) i dont want to damage the engine and the smoke is NOT alot firs i opened the trunk and since it was little i tought maybe is because is hot. so im going to get it inspected. also i am getting like 5 MPG
Originally Posted by SEmy2K2go
A leaking fuel injector would cause this too. Change your oil and if it comes out smelling like gas, STOP driving and fix the leaking injector ASAP. Hook your MAF sensor back up
... ... ... Check and fix all codes while you're at it.
Originally Posted by NmexMAX
Plug wires..
Wow. now that you mentioned i did not had these problem before the intake. what i did was i took the sensor from the OEM filter ans plug it and the CEL went off so i will go ahead and give it one more week to see if the milage is the same. I didnt think it was that because 3 or 4 days after i put the intake the white smoke came (only when i accelrated rapidly or when i went into the highway) so i thought that it was only because its hot. Didnt think it was from the simple intake but since the CEL came on with that code only i have that bad milage.
Originally Posted by scubasteve
I dont follow what point your attempting to make? A few people have suggested tune up as a remedy. Typically this includes the wires as well as the plugs. I don't see a tune up as a solution to his problem, so i said that "plugs, wires, etc" werent likely to be the answer.
so.. im taking the car sunday to determine what my car has, but i noticed something now i was at the highway and goingo like 60mph i noticed that i have the gas pedal like i was on circuit, so i think that maybe it is the pistons? i dont know for sure also mi car shuted down last night and it was a good 48 seconds (not a lot but people where honking like crazy) so my CEL wasn't on but when the car shutted and i (after hard work) started it again the CEL came on with code 0908 that is... Engine coolant temperature sensor. and i wanted to know. Is that bad or something i should take care of. or better yet does it has something to do with my bad gas milage. Thanks
