In the middle of VI swap, question on fuel rail
I"m in the middle of doing my VI swap, and I'm having a problem with the sx7r.com fuel rail off fitting leaking fuel. Is there suppose to be a gasket that goes in between the fuel rail and the fuel rail off fitting? Did anyone else have this problem?
Is sx7r's fittings the only fittings i can use or can i get them from a store? If so, where? Im stuck in the middle and dont know what to do with the 2 dampers on the fuel rail.... PLEASE shed some light to me on the fuel rail routing
on the regulator and on the damper, its a nipple & hose coming out the side and a nipple and hoses coming out the head(top) of both, but on my fuel rail its only 1 hose on the damper. What do i do with the other one?
Still not 100% sure what you're talking about but both of them need vacuum sources, the larger hose is the fuel and smaller is for vacuum. Fuel goes into the damper side & returns via FPR side.
