retrofitted projectors into oem 2k/2k1 housings? anyone done it here?
Just did a quick search to see if I could find any pics of a 2k or 2k1 housing with retrofitted projectors, but it doesn't seem like anyone has done them. I realise that the housing is quite large and may look funny with a small 2.5" or 3" dia projector, however I think a set of Q45's would look great with some custom bezels.
Anyhow, does anyone have any pics that they can post of 2k or 2k1 oem housings with retrofitted projectors?
My other 3 options for headlamps right now are either to use 5.5 gen headlamps, retrofit projectors into 5.5 gen headlamps (costly), or retrofit quality projectors into those cheap ebay projector housings...though the latter looks sort of tacky and they do not fit well.
Pic stolen from another user here of retrofitted ebay setup
Bosch e46 single, D4 ballast/bulb Retrofit
I just finished working on the electrical wiring for the driver's side of my retrofit project. I finally made some time to get it done cuz I've been putting it off for a long time. I ran into some problems and need to get some spade connectors. I'm using Dr. Roy's "common ground" wiring setup. Hopefully I'll find some time to test it before I work on the passenger side headlight.
still finishing up my project, E55 projectors, painted reflector and CF bezel, led side turn signal in orange, and parking light white. and 2k2 outer clear cover, which I had to modify the stock 2k-1 headlamp housing for a slight bend in lower slots.
I am working on this, as well. I have E55 (04-06 Maxima) projectors I'm retroing into an extra set of 2000 housings. I just finished the wiring harness and need to actually fit the projector... After my last final is over next Wednesday..
knight_yyz
Nov 1, 2015 01:34 PM
trsandrew
Oct 25, 2015 02:47 PM
atriuum
Sep 28, 2015 01:19 PM
...But thats only a dream since those projectors would cost me and arm and leg.
