Sponsored by:
Sponsored by: CARiD
00VI- tuning required for 00 lower/injectors?
Old Dec 18, 2006 | 02:05 PM
texasmax's Avatar
Well, gearing up to put in an 00VI (and rip out the MEVI), and spending all day at work reading up I've got a setup with 00 lower, fuel rail and injectors. Looking at Tatanko's GREAT setup comparison page, it looks like using the 00 lower and injectors requires "tuning". So, the question is, what exactly is required here- are we talking a timing advance or what?
Thanks all for your help. Searching didn't show up anything...
Old Dec 18, 2006 | 02:14 PM
gen4maxima536's Avatar
you at least need to do some A/F tuning using say a VAFC or SAFC and a wideband, since the 00 injectors are bigger and will be shooting in more fuel than the stock injectors
Old Dec 18, 2006 | 02:22 PM
texasmax's Avatar
Thanks! So, I've got 3 choices:
1- 4th gen lower/rails/injectors
2- 00vi lower/rails/injectors, don't tune it
3- 00vi lower/rails/injectors, tune it
If I go with #3, I'll just go all out and put in a Greddy EU, which I've been debating doing anyway.
But if I don't, am I sacrificing a chunk of power just going with #1? How about #2 (and what other issues might I have with #2...)?
Old Dec 18, 2006 | 03:02 PM
vipervadim's Avatar
I like Maximas
guess what you need a/f tuning with every single mod you install to get the best out of it.
for instance when i went from stock headers to ssautochrome headers there was significant flow change (butt-dyno feel) after i started messing with V-afc2 did i notice the difference in a/f. when i swapped the ssauto for hotshot headers the ssauto/00vi v-afc2 tune was working like **** with the hotshots/00vi, the a/f ratio was totally different at various rpms. because the flow and the amount of flow of air changed the ECU needs to be adjusted so the right mix of air and fuel is ignited throughout the rpm range, that's how you get maximum hp.
and i also have the dek lower/injectors.
Old Dec 18, 2006 | 05:49 PM
Cdg2125's Avatar
You're not going to lose power doing the 4th lower instead of 00 lower. Thats what I'm doing and I know Pat did it as well. Yes you will gain more results with a v-afc2 but then gains shouldnt be much, if any, different using the 00 lower or 4th lower. At least that's what I've been told by some of the other guys.
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
dshinn
Sep 26, 2015 08:07 PM
Socalstillen
Sep 26, 2015 12:01 PM
