Tokico Illumina Shocks & Springs???
Yeah, its an SE w/ chrome grille... *ebay*
Ok, cool - thanks a lot guys. So with the adjustable shocks is that for the stiffness?? Oh, I was thinking about just getting the shocks and torching(warm them up w/ a cutting torch) my stock springs to lower them a bit.
A harder setting will make impacts harder but keep your car from bouncing and wallowing around. A softer setting will increase the bouncing/wallowing but make impacts softer. You have to find your own balance.
As d00df00d said, it is a bad idea. The Tokico springs are progressive rate and if you were to cut your OEM's you probably bottom out alot.
Check out this link for more info: http://maxmods.dyndns.org/index.php?MaximaHandling
On ebay, how come the "Manufacturer's Part Number" are all different from performancepeddler? TOKILK204, TOKILK244, TOKILK234, TOKILK286, TOKILK262...
are the all the same though? they all have the same name: "Illumina Series Advanced Handling Suspension Kit," but the prices range from $500 - $598
I've just been informed by Dan from performancepeddler that they are out of stock for the 4th Gen maxima tokico kit. BTW if you're gonna change the struts you might as well get the strut boot and strut bearing. It is almost a sure thing that they are worn by now.
I also want to get a set of these
Where do I go to buy a tokico suspension kit with the springs. Couldnt find it on Ebay or on performancepeddler. Does this come with everything already put together and all I have to do is install it in car. Kinda like a coilover kit?
MaxLvr21
Oct 17, 2015 12:11 PM
Stagnet04
Oct 11, 2015 08:16 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
followthadollar
Sep 27, 2015 01:06 PM
