Removing 95-96 headlights to swap 97-99 ones?..
do you honestly need to post a thread for every little question like this?
yes you need to remove the grill. yes you need to take off the BOLTS* to remove the headlight assembly....
its a ***** to get to them? donno waht to tell you man....maybe you should just go pay someone else to do it for ya.
Remove the grille, you need to turn the square clips a 1/4 turn to remove them.
Remove the corner lights, phillips screw and used a long flat head to pry the ball and socket retainer apart.
Remove the 2 10mm bolts that are behind the corner lights and the 2 10mm nuts behind the headlight near the radiator.
Here's a question for you. Do you need to respond to every thread that was talked about before?
Mar 12, 2020 12:06 AM
t6378tp
Sep 29, 2018 04:27 PM
Hdnseek
Sep 9, 2015 05:55 AM
JoshG
Sep 5, 2015 10:10 PM
