Weird Starting Issue
Old Jan 13, 2007 | 09:04 AM
scubasteve's Avatar
OHHH YEA SCISSOR!!!!
Hey guys, how you been? I'm having a starting issue, need some slight insight. On cold (mostly, happened once or twice when not so cold) days, the first time i start the car for the day, it starts, goes to about 1k, sputters and dies. Then when i crank it over again it will sputter but not start. I turn the key off, wait a sec, crank and its fine.
Now if i start it the first time and hit the gas before it dies, it will idle fine. It's important to note that i always wait for the FP to finish priming before i start any vehicle, and the FP doesnt appear to be suffering any pressure loss, intermittent cut off, etc.
I was thinking coolant temp sensor since this didnt start till it actually began getting cold. I changed the battery after this started, no change. Thoughts?
Old Jan 13, 2007 | 04:10 PM
95jr6708's Avatar
Same problem...this insight was relatively useful and helped my problem, comming directly out of the haynes manual.
cold start issues relate to,
1.coolant temperature and/or intake air temperature sensors.
2. ignition switch
3. Fuel not reaching the injectors (ie fuel delivery problems)
4. dead/weak battery
5. corroded battery terminals especialy ground wires.
i think that was it.
based on your diagnosis, i would bet on ignition switch ( my problem ). good luck.
Old Jan 22, 2007 | 03:51 PM
scubasteve's Avatar
thank you for the input, i'll check into those. Sorry for the late reply, busy life lol
Old Jan 22, 2007 | 08:46 PM
andrei3333's Avatar
whats an ignition switch and how do i check it ?
i have the same problem EXACTLY
Old Jan 24, 2007 | 05:53 PM
frumundacheese's Avatar
where you put your key.
MAXSE5SPD
Sep 17, 2022 04:00 AM
mvm062
Nov 30, 2020 09:00 AM
Maxima30
Sep 7, 2015 06:13 PM
trungg86
Sep 4, 2015 04:58 AM
Jcof88
Aug 3, 2015 10:43 PM
