Rack and Pinion
Rack and Pinion
My drivers side rack and pinion is goin. I flushed my power steering 2 weeks ago and its already brown. Now its starting to make some nasty noises. How hard would this be to fix myself?
to change the rack would be a ton of work. when you say you "flushed" it how did you do that? just emptied out the resevoir and filled it back up? if so , then you didnt do a true flush. i would suggest some Seafoam Transtune and then a true flush using the return line.
If it's making noises, are you sure you bled it fully? That may be the source of the noise.
Also, I would not expect it to clear out if you just emptied/replaced it once. The original brown-colored fluid will mix in.
That all said, yes these power steering racks go bad. It seems to be kinda common. I installed a used low mileage rack on mine and it's helped a great deal. But it's no small job.
Dave
Dave
No small job is quite and understatement. It's a ***** pulling one out when half the car is parted out let alone when you have to be carefull to not bust anything around it. I've pulled a couple out of my parts cars and it stinks. Unless i sell them I leave them in when I haul them off.
well i did 3 flushes with one of those vacuum things. I even vacuumed out the tubes from and to the power steering fluid. I did a true flush. Is this something that deserves immediate attention?
Rack and pinion replacement job is a bitc4! Had mine replaced about 2 months ago and it looks very complicated. Took it to a shop, and watched them, im glad i paid them to do it, cause if i did it myself, i know i would have messed something up....
Suck the resevoir dry. fill it up with some Seafoam Transtune. Start the car and turnt he wheel lock to lock a good 20 times. Run it for about a week. That loosened up my steering. Then drain the resevoir again. remove the return hose from the bottom of the resevoir (the one that runs towards the cooler at the front of the car). place that in a bottle/jug container of some sorts. place your finger over the hole that the return line was. pour some ATF into the resevoir and have your helper start the car and begin to turn the wheel lock to lock. keep pouring ATF into the resevoir to prevent it from going dry. It takes about a quart to flush and another quart to fill. Some people claim Mobil1 Synthetic ATF works better but i cant speak on that. After flushing with the first quart, replpace the return line and fill. That is a proper DIY flush.
Originally Posted by njmaxseltd
You people kill me. Seafoam isn't a cure all. It's called advertising 101.
mikeg75
Nov 30, 2015 05:12 PM
fastcarny
Oct 12, 2015 07:06 AM
Serotta33
Sep 17, 2015 12:14 PM
