Rims/tire Sizes Help!!!!help Please!
Old Jul 5, 2001 | 06:11 PM
Deven2kStickMax's Avatar
Hello all Max stunnas/lovers. I have Eibach Pro-Kit, Tokico Blues HP and currently running on stock 16" SE rims. I need to change rims and i'm looking at a set of 17's on tirerack.com . If i used 17x7.5, what tires size is best for my car without rubbing and if i use 18x8, what tires size should i use. Any replies would be appreciated. Thanks.
Old Jul 5, 2001 | 06:30 PM
2001SE's Avatar
does this help:
http://www.miata.net/garage/tirecalc.html
Old Jul 5, 2001 | 06:38 PM
Originally posted by 2001SE
does this help:
THANKS A LOT 2001SE. I WILL LOOK INTO IT ASAP. THANKS AGAIN.
Old Jul 5, 2001 | 06:41 PM
2001SE's Avatar
No problem man
Old Jul 5, 2001 | 06:44 PM
2001SE, WHAT ARE YOU GUYS USING ON A 18X8 WITH EIBACH'S?
Old Jul 5, 2001 | 07:07 PM
UMD_MaxSE's Avatar
Got Bent?
235/40/18 would work well with 18x8 rims.
Old Jul 5, 2001 | 07:11 PM
Yeah i'm thinking of 18x8 with that tire size, but would it get enough clearance with the Eibachs?
Old Jul 5, 2001 | 07:13 PM
UMD_MaxSE's Avatar
Got Bent?
it should be fine as far as I know.....
Old Jul 5, 2001 | 07:18 PM
Ok UMD_MaxSe, i'll get them from tirerack. Thanks for the help Max Lovers.
Old Jul 6, 2001 | 04:51 AM
UMD_MaxSE's Avatar
Got Bent?
what kind of ris are you getting?
Old Jul 6, 2001 | 07:41 AM
Chillboy
I have eibachs with 18x8 OZ rims with 235/40/18 Sumitomos and there is plenty of room. when my tirethread wears though, im thinking of getting 245s. everything is awesome with the 235s but i still think the tires look too think from the front or back view. well, hope this helped. what rims and tires you buying?
Old Jul 6, 2001 | 02:16 PM
marky3320's Avatar
Try Discount Tire Direct
Check out www.discounttiredirect.com I think they have a better selection, plus they have the Konig Tantrums and Verdicts which would look cool on the Max.
Old Jul 8, 2001 | 03:57 PM
Re: Try Discount Tire Direct/Help
HELP. Does anyone knows if this tire/rim setup can work good with Eibachs? I need to know if it will rub on the fender and there will be clearance. Please reply someone. I want to buy them by discounttire.com
DUNLOP SP SPORT 5000 BLCK P235/45ZR-17
KONIG TANTRUM 17X7 5-114.3 40S
Old Jul 8, 2001 | 06:26 PM
UMD_MaxSE's Avatar
Got Bent?
Re: Re: Try Discount Tire Direct/Help
hmmm....the Konigs are 17" x 7". I don't think the tires are meant to be mounted on 7" wide rims. You may want to double check though. For 235 series tires, the rim should be 7.5" wide for most cases. Look for some 7.5" or 8" wide rims for the most choice in tires. People have mounted 235's on the stock 7" rims without any problems yet, so it may be ok. But I don't think the tire manufacturer would recommend it.
Old Jul 9, 2001 | 03:11 PM
Re: Re: Re: Try Discount Tire Direct/Help/Selling Stock 16 $500.00
ok I ordered set of Dunlop SP 5000 P235/45/17 and set of set of Konig Tantrum 17x8. I hope this doesn't works good with the Eibachs. They suppose to show up at my door Wednesday morning. I'm selling my Stock SE 16 with tires. Anyone interested i'm selling it for $500.00. They have on Michellin Pilots. 225/55/16 All season.
Old Jul 9, 2001 | 04:11 PM
UMD_MaxSE's Avatar
Got Bent?
Re: Re: Re: Re: Try Discount Tire Direct/Help/Selling Stock 16 $500.00
Sounds like a tight setup Post pics when you get the chance....
Miket2006
Mar 1, 2021 03:55 AM
RIPTIDER
Wheels/Tires
Jan 31, 2016 07:39 AM
knight_yyz
Nov 1, 2015 01:34 PM
