Cut-Out Exhaust Setup ?
Old Feb 11, 2007 | 07:18 PM
MaximA StyLeZ's Avatar
Any1 have any setups they can share? I am interested in getting a cut-out and would like to know how/where it was installed.
Would you be able to use the cut-out's y-pipe to weld and use in place of the cat ?
Any1 have any pics, ideas, pointers on install ?
Old Feb 11, 2007 | 07:24 PM
Fr33way™'s Avatar
Wild for Width
Are you boosted? If not it is just annoying AND wont make any gain.
Old Feb 11, 2007 | 07:28 PM
nah no boost for me , just looking for some more power i guess up top w/ the 00vi.
Old Feb 11, 2007 | 07:31 PM
glenmoormax's Avatar
10 psi
it will be loud, and not help out a whole lot, maybe 1 whp. I gained 3 whp with mine being where the cat should be, and i only netted 3whp because I am SC'd. that and I have a good catback, cattman/stillen FTW. just invest in a good catback sytem.
Old Feb 11, 2007 | 07:36 PM
i already have a stillen cat-back. Just trying to go back to stock w/ the option of open exhaust.
Old Feb 12, 2007 | 07:45 AM
Flava_24/7's Avatar
Boosted Panda
Im confused, how did you
"net 3whp because I am SC'd. that and I have a good catback"?
With the cutout open the exhaust wouldnt even make it to the catback so why would its type matter? And with it closed there would be no gains with it.
I wouldve have thought it would give a boosted car quite a bit more then 3whp.
I would have thought the gains would be similiar to running a 3" exhaust.
Did you dyno comparison to determine that 3whp?
Old Feb 12, 2007 | 08:25 AM
f550maranello2's Avatar
^^^^ werd i was about to ask the same... where on earth did u get 3whp from????? thats like me saying that i took a dump this morning and got better gas milage....
Old Feb 12, 2007 | 12:00 PM
XeroX's Avatar
Hella internets
was looking around and found this thread...
http://forums.maxima.org/showthread....=exaust+cutout
Old Feb 12, 2007 | 12:20 PM
Flava_24/7's Avatar
Boosted Panda
Originally Posted by XeroX
I was looking into this earlier this week as well. However i was planning on installing this in place of the cat, for a nitrous setup. Im assuming with a 75 shot or so, this might provide some gains while spraying...
Im very interested in hearing if anyone has tried this product out....might have better luck in the FI or nitrous section tho? just a thought...
yes, its been discussed in the FI section,..
http://forums.maxima.org/showthread.php?t=509301
http://forums.maxima.org/showthread....ghlight=cutout
And the cat section is where its normally mounted.
Im actually trying to find someone to put mine together. Most shops Ive gone to dont want to touch it.
Its basicly a test pipe with the cut out, welded onto it.
Fitment is tight, and most Ive talked to say that you cannot be too low or it will scrape.
Old Feb 12, 2007 | 12:21 PM
real good thread, thanks
Old Feb 12, 2007 | 03:55 PM
jac121479's Avatar
we had a dyno day out here 6 months ago and Mike (an org member in a 5th gen) gained like 7-8 whp with it open with his NA de-k. i'm a believer in these things. easy hp at a flip of a switch. scary loud though!
Old Feb 12, 2007 | 04:02 PM
dgeesaman's Avatar
Maintenance Monster
What I think of big loud exhausts on an otherwise normal car:
It is a tale
Told by an idiot, full of sound and fury,
Signifying nothing.
William Shakespeare, Macbeth, act 5, scene 5
Old Feb 12, 2007 | 04:08 PM
jac121479's Avatar
It is a tale
Signifying nothing.
wow, things just got wierd in here...
Old Feb 12, 2007 | 04:14 PM
XeroX's Avatar
Hella internets
Too bad this was a very informative thread untill you started pooping in here with irrelivant shakespeare quotes....do your research, this CAN provide gains...Maybe not for shakespeare...
BTW, as for the fitment, is there any possibility that we may be able to have this welded farther down the exaust piping to avoid sacrificing so much ground clearance? or would this not provide as good of gains?
Old Feb 12, 2007 | 04:19 PM
jac121479's Avatar
unless you did some banging on the sheet metal, space is the same all the way back to the 90 degree bend right before the gas tank. ground clearance has to be sacrificed unfortunately.
Old Feb 12, 2007 | 04:20 PM
96sleeper's Avatar
Im not boosted, I picked up around 6whp and 2tq from a cutout on the 3.0, and even more (over 10hp) with the 3.5...
It will not pick up much over a good catback, but there are gains. My b-pipe is not mandrel bent, but I do have a straight through muffler and I still gained that much with a cutout.
Old Feb 12, 2007 | 04:24 PM
10 psi
yes, I did, sorry to confuse, i guess i was thinking more in my head than i typed. I dynoed 3 whp less with out the open cutout. I was refferring to sc vs na part with me gaining more hp possibly because i am boosted, he isn't, so i would think it would give someone that is boosted more gains. My thread is in the dyno section. does that clear it up any?
Old Feb 12, 2007 | 04:56 PM
Flava_24/7's Avatar
Boosted Panda
There is actually a bit more space around the cat area.
Old Feb 12, 2007 | 04:57 PM
Flava_24/7's Avatar
Boosted Panda
Your right, boosted cars would see a much bigger gain over NA
Old Feb 12, 2007 | 05:28 PM
jac121479's Avatar
thats normally where they're installed via a test pipe, but even then they have to be angled down some for clearance, sacrificing road clearance.
Old Feb 12, 2007 | 06:29 PM
10 psi
its ot that bad, if you have a lip kit you want to watch your clearance, but driving around daily it never hits, but people can see it hanging down and always ask me, whats that? maybe i need to angle it up a tad more and drop the car more so they can't see.
Old Feb 12, 2007 | 06:41 PM
Fr33way™'s Avatar
Wild for Width
Did it change the shape of the curve slightly? or at all?
Old Feb 12, 2007 | 07:29 PM
I30_DRIVER's Avatar
i have my cut out installed before my cat (its still in place)
it actually sits on a y-pipe what i did is took out the extra long flex pipe section and replased it with a 4 inch flex section and that gave me just enough room do play around with
Old Feb 12, 2007 | 08:24 PM
I30_DRIVER's Avatar
ill put pics up tomorrow
and a video
Old Feb 12, 2007 | 09:45 PM
sounds very interesting..
Old Feb 12, 2007 | 09:53 PM
i30krab's Avatar
At JWT the difference between my 3" cutout open compared to closed was
22 FWH. Even clark was amazed at this figure.
Old Feb 12, 2007 | 10:16 PM
I30_DRIVER's Avatar
cut out
the cutout it self is on the y-pipe and the flex section is shortned alot
Old Feb 12, 2007 | 11:06 PM
Nealoc187's Avatar
SLOW
I gain about 40whp opening my cutout - even so, I'm getting rid of it because it because I hate it (the sound).
Old Feb 13, 2007 | 12:20 AM
i30krab's Avatar
I don't understand. When it's closed isn't it quiet?
Old Feb 13, 2007 | 12:26 AM
10 psi
turbo will obviously affect the difference.
I will be dynoing the SC max again here soon, and will try it again with some more pulls to confirm if indeed the open cutout helps by 3whp or more, like i30krabs numbers...
Old Feb 13, 2007 | 03:40 AM
96sleeper's Avatar
The shape of the curve was exactly the same, just more power everywhere. No loss at any rpm in torque or horsepower.
Old Feb 13, 2007 | 09:03 AM
Nealoc187's Avatar
SLOW
When it's open I hate it. I'm redoing my downpipe setup and I'm not going to include it when I redo it because I'm never going to open it again anyways.
Old Feb 13, 2007 | 09:27 AM
JeEvE's Avatar
Whats wrong with the sound when its open? Just too loud? Everyone seems to like how mine sounds open. I running a 2.5" exhaust after the downpipe with a Dynomax Super Turbo Muffler (non-straight through) and I plan to get the wastegate rerouted into the downpipe so it stays quiet under full boost w/ cutout closed.
I gained over 30whp with the cutout open.
Old Feb 13, 2007 | 11:31 AM
mastercater7's Avatar
VQ35 FTW
where do yall buy the cutouts at? how much they usually run for?
jac121479's Avatar
Nice!!!!!!!!
Old Feb 13, 2007 | 11:55 AM
Flava_24/7's Avatar
Boosted Panda
This is where I purchased mine from...
http://www.quicktimeperformance.com/QTEC/
Old Feb 13, 2007 | 12:49 PM
jac121479's Avatar
that 13 second tundra is too cool, with its bed bouncing burn out. cool stuff!
Old Feb 13, 2007 | 04:18 PM
VQ35 FTW
so im guessing you just gotta weld flanges on to it?
Old Feb 14, 2007 | 06:43 PM
Nealoc187's Avatar
SLOW
i don't know, it sounds like ****. I hate the sound of the VQ. You're asking aboutsomething that is purely opinion so that's all I can say.
Old Feb 14, 2007 | 06:46 PM
Nealoc187's Avatar
SLOW
Nice!!!!!!!!
He's turbocharged. NA cars are going to gain more like the 3hp being attested to. 7hp if you have a decent NA buildup like a cammed 3.5 like 96sleeper.
