View Poll Results: What to do with faulty MAF sensor?
Clean it
29
47.54%
Replace it
32
52.46%
Voters: 61. You may not vote on this poll
Clean or Replace MAFS??
Old Feb 25, 2007 | 07:45 PM
Infamous95's Avatar
ok... need some opinion on this... i've been told by some that u can clean a dirty mafs..... n then i've been warned by otherz dat the mafs is not something u mess wid... in fact either replace it.. or live with it..
so... if possible... how to clean?
if not.... where to get a new one besides paying $200+ at slealership??
Old Feb 25, 2007 | 07:51 PM
2da mizzax's Avatar
http://www.crcindustries.com/auto/co...x?PN=05110&S=Y
$7. buy it. use it. If it doesnt solve your problem, dirt is not your problem and its time for a replace.
Old Feb 26, 2007 | 01:40 AM
Trajiksmax's Avatar
Proud Maxima Owner
I did the same thing that 2da mizzax recommended. You can find the MAF cleaner at your local Napa. "So easy even a caveman can do it."
Old Feb 26, 2007 | 07:14 AM
jltibbs's Avatar
also be sure to check the wires that lead into the plug that plugs into the MAF. i went through 4 MAFs before i found out that those wires were just coming loose. resoldered and good to go
Old Feb 26, 2007 | 09:01 AM
99grnmaxgxe's Avatar
Do you need to clean or replace it? Or do you just want to?
Old Feb 26, 2007 | 09:12 AM
MDeezy's Avatar
all of the above. test and check the MAF, clean it, re-test. Replace if necessary.
Old Feb 26, 2007 | 09:18 AM
Infamous95's Avatar
well the thing is that my car iz turnin off by itself... occasionaly... n all da symptoms fit with a dirty/faulty mafs... so im gonna try to figure out how to check it tomorrow.... while cleaning my tb and iacv... hopefully i wont need a new mafs... but still wanna know wat i need to do if it does turn out to be the culprit...
Old Feb 26, 2007 | 09:28 AM
MDeezy's Avatar
if it is bad replace it, un bolt it and swap in the new one. check the org classifieds for someone selling it, or check car-part.com
Old Feb 27, 2007 | 06:17 AM
ZaxWhite97Max's Avatar
Just go replace ALL your sensors at once. That way your broke AND your car runs nice. :-) Tis what I did. (sept i didn't go broke)
Old Feb 27, 2007 | 06:57 AM
willard00's Avatar
thats probably the worst idea ive ever heard.
dont listen to the people who say to just replace it. as you said above, youre not ever positive if thats the problem. try the MAF cleaner from autozone. it costs $5 and takes like 15 minutes if that. if that doesnt help and you really suspect the MAF is the problem then you can replace it. but still, ide at least try n test it before just replacing it, just to make sure that im not wasting a couple hundred.
Old Feb 27, 2007 | 08:36 AM
mist max2000's Avatar
i have a 5th gen,.. but i cleaned mine with the maf spray.. and it fixed it but the prob soon came backwithin a few weeks and i bought a new one and that fixed the prob.. so heads up that the cleaning spray might only be a temp solution...
Old Feb 27, 2007 | 09:01 AM
2da mizzax's Avatar
5th gen adn 4th gen mass air flow sensrs are 2 totally different beasts.
Old Feb 27, 2007 | 01:21 PM
alrite ,.. im just puttin my input on my experience going through with the 7 dollar spray and the 100 ish dollar part,,... in my experience with cars all sensors are usually sensitive to cleaning sprays so just be careful..but what could it hurt..
Old Feb 27, 2007 | 09:07 PM
esdsix's Avatar
Ok! Anyone with great technical experience on 97 Maximas? Heres the problem Err P0105 Map/Baro. The car wouldnt pass smog cause of that engine light that wont stay off after reset. I was told my MAF was bad after some tests were run in diagnostics. I replaced it with a new MAF, had the err reset, then BLAM 1 hour later, the light goes back on again... What is the problem....Irritating! Cause I cant get my tags until the smog test passes with the light off and the part fixed. But what part is it! Whats the problem? I even had a Nissan Specialist test it and say it was the MAF. So, somethings being overlooked, I would very much like to get some help with this.....Anyone experience the same? Could it be a wiring issue or something?
My smog passes great, but the err light is denying my pass once its been detected......HELP!
<a href="http://photobucket.com" target="_blank"><img src="http://i126.photobucket.com/albums/p112/xisdse/MAXIMAFORUMSSmall.jpg" border="0" alt="Photobucket - Video and Image Hosting"></a>
Old Feb 27, 2007 | 09:14 PM
2da mizzax's Avatar
That code is for the Absolute Pressue Sensor. It is bolted onto the scoop of yoru air intake right at the front of your car. It says "boost sensor" on it.
Old Mar 1, 2007 | 09:09 AM
meccanoble's Avatar
Sports Button FTW
clean it? blah, i've never seen anyone on here that cleaned their MAF and didnt have to replace it shortly afterwards. A clean may temporarily fix it at best but replacement will still be due soon. I wouldnt take the chance of V10 gas mileage and Civic performance to save on a maf that will most likely need replacing soon anyway....my opinion
Old Mar 1, 2007 | 01:36 PM
FanaticMadMax's Avatar
The term "faulty" is something that can't be fix, I say replace, but if it's something that need to be clean, then you clean it with brake cleaner, the same stuff you clean your rotor to remove grease and other element, it's safe to use on MAF. I never had an issue with my MAF since my acquistion six years ago. After reading the posting about MAF issues, I did clean mine with brake cleaner just for preventative.
Old Mar 4, 2007 | 03:58 PM
2da mizzax's Avatar
faulty means its not working right. how does that mean it cant be fixed? and why would you use brake cleaner when mass air flow cleaner is readily available. that just makes no sense.
Old Mar 4, 2007 | 03:59 PM
gunny11218's Avatar
lmao thats funny as hell
Old Mar 6, 2007 | 07:34 PM
tbergma1's Avatar
HOLY 4x4 BATMAN!
just kidding gunny, Try cleaning it so it will pass smog then get a new one when you feel like it. If it doesnt work, you just blew 7 dollars, big deal
Old Mar 7, 2007 | 08:54 AM
mGaxLimEa's Avatar
i would check it with a volt meter make sure its broke , check the wire leads an see if there loose replace if needed dont clean it the cleaners will work but not 4 ever just replace it. MAF work by measureing pressure and temp with a bimetallic strip in the housing and those u shouldnt *** with.
Old Mar 7, 2007 | 06:59 PM
2da mizzax's Avatar
So if using a MAF Cleaner fixes the problem............then the problem was that the MAF was dirty right? So why wouldnt it work "forever"? Its not like the MAF cleaner is some sort of patch. If the Sensor is bad, cleaning it wont help. And if cleaning it helps, you have solved your problem.
AnsonJ
Jun 2, 2017 01:35 PM
95Maxi
Aug 29, 2015 09:38 PM
vanebecker
Aug 19, 2015 09:45 AM
Samedi
Aug 13, 2015 04:05 PM
