Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
Removing OTHER car paint from my car, need help
Old Mar 17, 2007 | 10:53 AM
jaep0913's Avatar
Ok, so I was in a hurry, being careless, etc., and I lightly scraped the edge of my bumper on the corner of the garage. There was no structural damage, but a bunch of old, red paint got onto my bumper. I tried to wash/scrub it off, but it only helped a little.
Does anyone know of a good way to get this paint off of my car?
Old Mar 17, 2007 | 05:22 PM
Bluesbrekr's Avatar
Doctorate in Detailing
A mild polish/paint cleaner ought to do the trick.
Any pics? That would help us know how much paint and the extent of the scrape. Being on the bumper, there may be some scuffing that may not polish out, but you should be able to remove all the red paint.
Old Mar 19, 2007 | 09:53 AM
clayman88's Avatar
Be sure to try some clay before polishing.
Old Mar 19, 2007 | 01:13 PM
StL06MAX's Avatar
Second on the Clay Bay
Old Mar 19, 2007 | 08:57 PM
Xmax's Avatar
Try some wet sanding if the above does not work. First 2000 grit, if that doesn't work then try 1500 grit, if that doesn't work then 1000. You might need to use a harsher grit but that might require repainting. But if 1000 or 1500 grit works then work your way up to a finer grit to 2000. After that, you need to use some rubbing compound and elbow grease to smooth out what the 2000 grit couldn't. After that look into something finer than the rubbing compound, such as Meguires swirl remover. Once that is done use some clay bar to remove any fine particles in the paint. Then once that is completed Apply good quality wax. Note: Between grits wash and clean the area that you working on to prevent any large particles scratching the surface and making it worse.
Lakersallday24
Jun 16, 2019 01:35 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
kirkhilles
Aug 8, 2015 10:53 AM
13Maximasv
Aug 7, 2015 10:56 AM
