Transmission bearings?
Old Mar 25, 2007 | 08:55 AM
Maxi98se's Avatar
Ive been recently experiencing a Whirrrrring noise while driving. You can only hear it when your in gear and it goes away when I shift into neutral. My mechanic says my transmission bearings need to be replaced. Anyone have any experience with this or replaced them before??? Tia!
Old Mar 25, 2007 | 11:18 AM
dgeesaman's Avatar
Maintenance Monster
It's basically what they do when you get your tranny rebuilt.
Plan on changing all the bearings. It can be done DIY but you'll need some pullers, dial indicator, and you'll want to re-shim the bearings. So it would take a while before you get your car back on the road.
Check the oil level in the tranny more often. Worn tranny bearings usually result in leakage of gear oil at the axles, and if you lose enough oil you'll cause the damage to get even more aggressive.
Dave
Old Mar 25, 2007 | 12:06 PM
Maxi98se's Avatar
I check the oil level in the tranny I wanna say every other oil change. When I do, it has always been fine. The tranny shifts smooth but the noise is definetly there...
Old Mar 26, 2007 | 09:34 AM
dgeesaman's Avatar
Maintenance Monster
Then you are running on borrowed time.
If you plan to have this tranny rebuild, the sooner you do it the less likely it will have expensive damage. (In other words, now is more likely to be a bearings/seals rebuild, and later could involve a whole lot more)
Dave
Old Mar 26, 2007 | 04:58 PM
Maxi98se's Avatar
Its getting fixed... I dropped the car off at the shop today, Im gonna pick it up either wednesday night or thursday morning i miss her already
The mechanic is replacing all the bearings and seals.....
Old Mar 27, 2007 | 01:56 PM
dgeesaman's Avatar
Maintenance Monster
MAKE SURE THE MECHANIC VERIFIES THE ENDPLAY OF THE DIFFERENTIAL CARRIER.
90% of the time the factory did not set it correctly, and if it's only a 2-3 day job it's highly unlikely these shims are in the plans.
Dave
litch
123
Jan 4, 2024 07:01 PM
user 11122324
42
Jul 18, 2022 03:35 PM
220k+ A32
25
Oct 3, 2015 09:09 PM
Andy29
Sep 29, 2015 05:32 AM
