FS: Zeitronix Wideband Bundle w/Black LCD Display
FS: Zeitronix Wideband Bundle w/Black LCD Display *SOLD*
*SOLD*
From site:
NEW!!!
Zt-2 + BLACK LCD Display Bundle.
New black anodized aluminum case. This is a very nice and deep shade of black, not cheap grayish black imitation anodizing.
Includes the Zt-2 Wideband Air/Fuel Ratio Meter, Wideband Oxygen Sensor, Sensor Harness, Signal Harness, PC Serial Cable, Datalogging Software, Installation Instructions, 2 pin EGT connector to retrofit your EGT probe and Zeitronix LCD Display with peak and hold feature. High contrast LCD visible even in a direct sunlight.
Also bought the Boost sensor for it:
This means vacuum and 35.3 PSI gauge at sea level.
Military grade sensor with unprecedented accuracy, also used in nuclear applications.
Not being happy with available on the market MAP sensors we adopted this great sensor to be used as a MAP sensor for precise manifold vacuum and boost display and logging.
Less expensive than most peak and hold boost gauges. Connecting harness and hose barb included.
Brand new still in plastic and in box.
$500 value, you can take everything for $400. Basically throwing the Boost sensor free. If you don't want the boost sensor, I can do $350. And the Boost sensor will be FS for $50.
More info on the wideband here.
From site:
NEW!!!
