RPMS hang up then drop...5spd
Old Apr 5, 2007 | 10:11 AM
95bluse's Avatar
Hi guys,
I have this ongoing issue where (especially in cold temps), my rpms don't drop all the way down to idle when I roll to a stop.
Here's scenario 1:
I coast to a stop, clutch in, my rpms may drop from 2k to about 1k at the normal rate but then stays there for a couple of seconds and drops to idle when I come to a complete halt.
Scenario 2:
Rpms drop as above, but it may go down to around 800rpm, briefly rise to just under 1K, then drop to idle.
What's consistent is that it will drop to idle, which is quite smooth, when the car comes to a halt. It's very irritating, because I don't get that engine braking all the way down, feels as if I'm driving an auto and having to use the brake.
What's done so far:
- Took off TPS and verified it's not sticking. I used a digimeter to test it while on the car as per FSM, looks ok
- changed plugs (using Iridium IX) & fuel filter (Z32), cleaned K&N drop-in filter,TB & MAF. Even ran some Redline SI 1 Fuel system cleaner in the tank.
- IACV valve may need cleaning ( was last cleaned 2yrs ago)
- No codes ( checked last week)
- Car has a leak at the muffler flange
- Can't detect any vacuum leaks though the intake plenum gasket (front)needs to be replaced.
- Lots of kilometres 490,000km about 270K miles
Any ideas?
Old Apr 5, 2007 | 11:52 AM
95bluse's Avatar
*BUMP*
My post is getting bumped my pics of rims & tires? wtf
Old Apr 5, 2007 | 12:15 PM
darklegend06's Avatar
I recently finished my 5spd swap and I have the same issue as you. Is your car originally a 5spd maxima, or is it converted?
Old Apr 5, 2007 | 12:28 PM
95bluse's Avatar
Original 5-spd...I wonder if this is a sensor issue? I've never replaced any front o2 sensor...then again it could be TB issue...I have to go re-read my FSM
Old Apr 5, 2007 | 01:35 PM
icedout's Avatar
on my car is was my iacv that needed to be cleaned and it was as good as new after that....
Old Apr 5, 2007 | 02:25 PM
Maybe I should clean mine too, I'll try that out this weekend
Old Apr 5, 2007 | 02:37 PM
95bluse's Avatar
Was your symptoms the same? I'll clean out mine either way, just waiting for it to warm up here a bit. I think I'll also make the pcv catch can, should keep the TB a lot cleaner.
shilov
Feb 19, 2024 09:40 PM
Unclejunebug
Apr 2, 2016 05:42 AM
ef9
Oct 4, 2015 08:43 AM
Need help
23
Oct 2, 2015 08:56 AM
