My custom semi-cold air intake.
- Relcated battery, it wasnt to hard with the help of a friend. Used a drill grinder/dremel and made 2 brakcets to hold the tray and one for the Fuse Box.
-Made it from old intake pipes I had laying around. Still need to buy matching couplings, I had these laying around so just through them on.
- Sprayed with undercarige coating to resist heat. (have to redo cause I didnt have enought time to let the thing dry)
- Cut the braket mount on my MAf and also removed the screen before the MAF.
- Bought a huge K&N filter.
- Im also thinking of making some kind of heat shield.
- The car feels better, Safc air flow goes to 75% now ,also when I pop the hood after a long drive the filter area is much cooler behind the battery.
What were the readings prior to the mod?
Originally Posted by nismopc
Excellent job on the battery relocation. Personally think that is a great idea. Wouldn't take much to shield off the rest of the area and create a enclosure for the filter and pipe in some fresh ait from beneath.
Readings before was about 72, but that also with my auto zone intimidator cone
After I removed the battery I thought about cuttin a hole to make a true CAI, but then thought about water and etc, and didnt wanna go throguht the trouble.
Good stuff my dude! Im actually gonna do this as soon as this stupid Connecticut weather breaks. As for the shield, i have a battery housing (where the battery sits in) from a ford E-150 thats big enough to fit around that K&N..Im gonna drummel out the lil plastic squares inside the battery housing and bolt it down...As far as cutting out a hole in the fender well...Water might be an issue...but it might be safe you never know...Anway, great idea. Dont mind me usin it
Not sure why he's keeping his stock MAF housing. He has a SAFCII so he could safely use the Land Rover housing unit, and instantly realize better throttle response as well as a few other added bonus items.
Looks like an A34 Injen unit. Done for cheaper though.
Originally Posted by STILLENGLE
nice dude thats awsome
sig rules http://forums.maxima.org/showthread.php?t=512019
not to be a hater or anything but that filter is only 3' in diamater which is choking your engine 3.5 inch to the MAF housing and a 3.5 or 4inch diamter filter would flow at least 100CFM or more without any loss in performance, youll gain more with a slightly bigger intake 4cyl cars need 3in 6cyl cars need 3.5 inch v8's need 4 inch or better
Originally Posted by MaxBoost925
But it looks kinda ghetto.
Ya i know its ghetto, but its made from pipes and couplings i had in the garage, and i started the project alittle late, didnt have time to let the under carrige paint dry......Needed to drive the car that night
Basiclly it costed me 60$(cause thats waht i paid for the K&N)
Nemax gimmie more info on the range rover MAF bro.
I was about to buy aarons spacers, but I needa new clutch , 103k its just not taking the beating im giving it. Also cause im going to the track in june or july and it wont lat till then.
TB = 70mm. (2.75")
I know all that sounds good, but its not right bro....Sorry....
Either wat the filter inlet is 3.5, i Had to do some special stuff it to fit on the 3" pipe..
Welcome to the forum.
Originally Posted by Osburn2027
what did you have to do to relocate the batterty
Had to cut one bracket that was on the side, other than that I drilled the stock battey holder and just got it to fit.
If you good with a drill and a dremel tool or somthing like it, youll be ok.
I didnt have to thread any new holes or anything.
ehhh i think u need help lol... u gotta host the pic somewhere... webshots.com
or photobucket.com or somewhere and then link it to that,.. well thats one way to do it anyone.. u cant link off ur desktop lol
I used a drill bit to make a scuare hole by drilling many time to make a hole bigenough for a sawzall. then i had to use an air cut of tool for some finall triming. Also i got all my tubing and filter from autozone it was like 70$ including the filter
i was able to relocate mine using existing hole no custom fab requred. pic coming soon'
Now all I've got to do is see if HD will take the bar that I bought back???
for the creativity.
Your max is hot I saw you getting on Rt.9 Northbound sounds good
Image linked to Desktop
