need help with 4th gen vq35 swap
hey guys i need some help....
i cant get my car running...
i put in a 3.5 motor in my 96 fed spec maxima se
i bought cam spacers from stephenmax and installed the timing correctly
i can post up pics so that u can check on it if u want me too....
my car turns over and i have spark but what can that be from???ground??? sensors??? timing???etC????
need help asap...
need help asap...
Originally Posted by scrhale
I remember there was one guy who setup his fuel system backwards. The car would barely start and then choke and die. It is always the small things that get us.
I would rather have a problem like that than a timing problem.
Originally Posted by Nismo3112
1. make sure all sensors are plugged in and working properly
2. make sure you have the fuel correctly setup
3. check for codes
3. check for codes
the only thing that pulls up on my scanner is the evap sensor thats on the top of the 4th gen intake manifold...
other then that my car turns over....
im running a stock 3.5 fuel rail.....
i got a walbro fuel pump ...
the hose from the fuel filter connects to the 3.5 fpr....
would timing jump if everything is put together???
Originally Posted by nismology
Could you please elaborate on this?
from the fuel filter, it connects to the 3.5l fuel rail...
direct from the fuel filter to the fuel rail...
Originally Posted by UNDEFINED76
the feed line is the line coming from the fuel filter side right??
You need some sort of fuel pressure regulator in there.. It's a "damper" on the end of the stock 3.5 rail, not an FPR.
My guess on what's happened:
1. No FPR, you dumped way too much fuel when cranking
2. Plugs are now flooded
3. no starta
Anyway, you're on track with the no FPR thing. Wayyyyyyy too much fuel pressure if that's the case...
hey guys....heres an update....
i got a 3.5l in my 96 max se running but need some help...
heres my mods:
2002 maxima motor 3.5l
1997 maxima trans 5 speed
bomz intake
warpspeed y-pipe
fpr: ghetto rig stock fpr...
as far as my sensors and ecu, im running a 96 fed se ecu (stock)...as far as the sensors i have the map/boro hooked up to the tb vaccumm line...i dont have any iacv sensors, and egr sensors...the only sensors i got is the tps, map/boro,crank sensor(2), cam sensor, oil pressure sensor, o2 sensor...i might be missing a few but cant think of it at the moment......
ordered a aftermarket universal adjustable fuel pressure regulator...what should i set it to??
car is running but need help with starting...it doesnt start up right away....i gotta crank it awhile for it to start....any ideas???
could it be the fpr because im running the stock one???
i got a ur crank pulley but cant take it off my old motor...i used a impact gun(ings impact gun with 1000lbs of loosening torque) and still cant come out....any ideas???
as far as ordering a e-manage ultimate, where can i get the best deal???
heres my mods:
bomz intake
warpspeed y-pipe
CHECK CODES FIRST MAN!!!
poor ground between the bellhousing mating surfaces? http://forums.maxima.org/showthread.php?t=452286
MAXSE5SPD
Sep 17, 2022 04:00 AM
