cat remove
Old Apr 25, 2007 | 06:25 PM
Osburn2027's Avatar
cat remove
any body cut there cats off what was the result as far as power and noise
Old Apr 25, 2007 | 06:27 PM
Greeny's Avatar
¯\(°_o)/¯
No gain at all,most cars will loose power without it..
Old Apr 25, 2007 | 06:29 PM
Osburn2027's Avatar
is it cause of the a/f ratio if so will a piggy back fix this
Old Apr 25, 2007 | 06:32 PM
Greeny's Avatar
¯\(°_o)/¯
Go for it..
Old Apr 25, 2007 | 09:11 PM
xx-Marshall-xx's Avatar
kthxbye2u
would it run rich or lean?...
Old Apr 25, 2007 | 09:27 PM
Jess's Avatar
SHIFT_In2D
It will run rich.
Sound is slightly diffrent.
Get a test pipe / fast cat from CP. For those just incase scenarios when you need to pass emissions later on.
I'm running CP Y-pipe 2.5" exhaust w/out cat. it smells...just so you know.
Old Apr 26, 2007 | 12:53 AM
Theyears02's Avatar
running y-pipe w/test pipe. you cant feel it but track times show a small improvement. no smell problem here, just smells like it shoud...not clean
Old Apr 26, 2007 | 01:18 PM
NmexMAX's Avatar
dot dot dot ...
I saw a gm/s increase @ higher RPM w/o it.
Old Apr 26, 2007 | 05:57 PM
getbigtony's Avatar
u'll get 1-2hp from taking off your cat for a test pipe;
worth it?
Old Apr 27, 2007 | 03:19 AM
Nismo's Avatar
Well, I tried cutting my cats once, I got clawed.
Don't do it...
Old Apr 27, 2007 | 05:42 AM
markd248's Avatar
I don't think the added pollution and having to pay for an inspection ticket makes it worth 1-2 hp. Get something else that'll get you more hp and less headaches!!
Old Apr 28, 2007 | 02:16 AM
Nismo's Avatar
like a turbo
Old Apr 28, 2007 | 06:42 PM
kthxbye2u
well i dont have to worry about emissions in florida
Old Apr 28, 2007 | 07:26 PM
Osburn2027's Avatar
nor do we in arkansas
Old Apr 28, 2007 | 08:07 PM
NmexMAX's Avatar
dot dot dot ...
Nor NM...>..>
Old Apr 29, 2007 | 11:12 AM
machinehead131's Avatar
I am using a test pipe, then for emissions pop my cat back on.
Old Apr 29, 2007 | 05:22 PM
Theyears02's Avatar
sadly, i would be willing to bet that you can pass emissions without the rear cat as long as the precats are still installed/working. obviously headers/test pipe wont pass. but really it might not fail by much. cars run real clean these days
maxinout93
Oct 31, 2015 02:04 AM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
