Replacing rack and pinion...what additional parts do I need?
Hi Everyone:
It looks like my steering rack is leaking, and needs to be replaced. My mechanic wants $800+ to do the job. I looked around and can get the rack and pinion part for around $200, so I think I'll do it myself. I have the FSM, but I've never done this particular job before.
Do I need any other parts to get this replacement done? Any bushings or bleeding kits or anything? Any tips from someone who's done this before?
Thanks,
Matt
Thanks,
Matt
Are the boots the same as the bushings?
Originally Posted by x91max
the gaskets theres like 2 and if it doesnt come with boots then boots but i think most of them do now. some come with tierod ends and some dont. i wouldnt use the old.
Originally Posted by newmaxguy
Ok great. Sounds like my list so far is:
Rack and Pinion
Boots (if my R&P kit doesn't have them)
Tie Rod Ends
Bushings
What about bleeding the system after I'm through? Any tools needed there?
Matt
Rack and Pinion
Tie Rod Ends
Bushings
Matt
the new rack should come with boots. otherwise don't get it. i already did this not too long ago on my car as well. at first it seems hard but once you are in there it gets easy. get new rack bushings from Nissan, new outer tie rod ends. also make sure that when you get the new rack make sure it comes with 2 new O-rings for the high and low lines. if they don't then get them cuz you have to replace those once you install the new one. if you need more info, i made a thread when i was replacing mine. go there --> http://forums.maxima.org/showthread.php?t=507390. enjoy and have fun.
there is 1 thing we forgot to mention.
get it ALIGNED as soon as possible after the rack is installed.
Thanks everyone. I will get it aligned the next day.
My final shopping list is:
Rack and Pinion kit (with boots)
Rack Bushings
Tie rod ends
O-Rings for the high and low lines
Break bleeder kit
ATF fluid
Anything I've forgotten?
Matt
Rack Bushings
Tie rod ends
Break bleeder kit
ATF fluid
Matt
why a brake bleeder kit?
O-rings should come with the rack too.
Bleeding procedure per fsm:
1. Raise front of vehicle until wheels are clear of the ground
2. add fluid into tank to specified level, turn steering wheel quickly from left to right,lightly touching the steering stoppers..repeat procedure until fluid level stops going down..
3. Start engine, then repeat step 2 with the engine running...
I was just about to get out the FSM and read this section.
Matt
Ok, talk about adding insult to injury. I just took the car to Costco to get a new tire (the state inspection failed because the tread was too low on one of them.)
The told me they wouldn't cover the tires warranty because the alignment was off.
So, I've ordered 2 new tires, but here is the question: He told my wife that the Camber is broken. (At least that's how it got to me.) Could that mean something is broken? Or does it mean it just needs an alignment?
Since I'm replacing the rack and pinion this weekend and having it aligned, is there anything else in there I could replace, alignment-wise?
Matt
Matt
Ok, I asked some more questions about what he actually said. He told her that the tires were both tilting in, so the "camber must be broken."
So, same question I guess. Does this mean a camber bolt is broken? Or maybe it just needs an alignment.
Ok, so a few new developments in the story. My wife isn't feeling so great about fixing the max and using it as our main family car. With mounting problems and high miles, I don't blame her. I'd hate for her to be stranded on the freeway with my son.
So, we ended up buying a used car. An 02 Avalon.
I kept the Maxima though, believe it to have much more life in it. So, with my money all gone, I'm trying to find ways to cheap out on this fix.
Here is my plan, see if you find any flaws here:
The Steering leak is small. It must be, because I never see any actual fluid coming off the car. No puddle under there. So, I want to drain the power steering fluid out (if that's possible), and replace it with the right ATF fluid, and some of that fix-a-leak stuff.
I'll do the other fixes that the safety inspection wanted (rotors, alignment, 2 tires). Then I'll power wash it under there, and get it over to the inspection station. Maybe the leak will have stopped enough to pass? (me crosses fingers.)
In the end, even if it doesn't, it's worth a shot. I really hope it just needs an alignment, and not new control arms or bushings etc.
Matt
Matt
Matt
Matt
Originally Posted by jimbo2006
Use Dexron III only. Easy to do. Buy turkey baster (cheap) or siphon. Open power steering reservoir cap, remove filter, remove all the old fluid you can through the cap (down to the bottom of the reservoir). Replace filter. Fill with Dexron III. drive car for 1 week. Repeat drain and fill. Do this again after one more week and you will have almost all new fluid in your system. this may even give your old seals new life and stop a minor leak. It did for me. DONT use fix a leak stuff.
MaximaDrvr
Aug 19, 2015 08:20 PM
kirkhilles
Aug 8, 2015 10:53 AM
laparka66
Aug 6, 2015 09:36 AM
ViciousVQ30
Aug 5, 2015 05:40 PM
