A/C Leak
Old May 7, 2007 | 07:58 PM
SouthStar019's Avatar
A/C Leak
About two months ago i filled the A/C system with the R-134a 2 bottles. and now its empty so i bought some of the refigerent with the UV dye in there and put it in. direcly after putting in some i saw this. i circled it. i am sure this is not normal but do you guys have that hole in your system also?
link to bigger picture if needed.
http://img201.imageshack.us/img201/9729/1002248wy1.jpg
Old May 8, 2007 | 06:49 AM
oldngivout's Avatar
Willing to learn
You, my friend, have an obvious hole in your AC hose. This hose must be replaced before attempting another recharge.
It will never hold the refrigerant as is.
Old May 8, 2007 | 07:52 AM
yea i figured thats the hole. any one know how much the hose goes for?
Old May 8, 2007 | 08:39 AM
dla's Avatar
dla
That looks like the low-pressure flexible hose, I couldn't find the Nissan p/n. I think there are o-rings on each end that should be replace at the same time. I would call your local dealer and start from there.
Or go to Gates:
http://www.gates.com/part_locator/in...cation_id=3598
and fill in category, year, make, type and model and you will find two AC hoses. One the upper and one the lower. I came up with gates p/n 22963 and 22964. Not sure what one you need, but they run about $9.00
http://www.rockauto.com/dbphp/mak,NI...IMA%204%20DOOR
I've never replaced this hose, and never purchased through either one of these sites, just used as a reference.
Good luck
Old May 8, 2007 | 11:31 AM
ok just got off the phone with nissan. the low side hose goes for $117
and part number is 9248 7Y105.
i looked at the gates and rockauto sites. can those be the same hoses?
Old May 8, 2007 | 03:28 PM
dla's Avatar
dla
After further review, no they are not the same. My mistake, I got off looking at coolant hose (the fat ones that carry antifreeze) not AC hose. Huge difference. I'm a little shocked at the $117!
Old May 8, 2007 | 05:58 PM
yea i checked up courtesty parts and got 86 dollars.
i for got to put a 0 in the part number its actually
92480 7y105 for the low side.
where else can i look for this?
thanks for the help.
Old May 8, 2007 | 06:02 PM
Longhorn101's Avatar
Well, I was wondering if i was the only one that got one of these bad hoses, but it appears that I wasn't. My leak was in the exact same spot on my '04. I was very disappointed to have a hose on a ~3 year old car go bad so soon. I had a local shop get the part from Nissan and install. The part was about ~$120 and labor for change out, vacuum and recharge was another $100. I think that was a pretty good deal, but didn't really price it out. I'm sure the dealer would have stuck it to me a lot worse.
Anyway, AC has been working well for about a month now. Good luck.
Old May 8, 2007 | 07:24 PM
well the a/c had almost no charge now rite now. so i dont have to worry about the vaccume part and replacing my self. looks fairly easy.
exact same spot huh?
Old May 11, 2007 | 10:37 AM
does any one know if this hose comes with new O Rings or not?
Old May 11, 2007 | 05:52 PM
Exact same spot.
Old May 12, 2007 | 10:23 AM
minsbang's Avatar
I spent $125 to get my a/c charged few weeks ago and now it's not working. I took it to the shop and they said that I have to get a new hose and quoted me $275 fix the problem. I don't have the time to compare prices so I guess I'll just have to eat it..... I'm just disappointed at the fact that from a 3 year old car, I have to go through this... but then again, my car has 104k miles.
Old May 12, 2007 | 10:57 AM
wow. 104K? drive alot. did they tell you which hose needed to be replaced?
Old May 12, 2007 | 03:21 PM
chernmax's Avatar
Nations 1st 6th Gen Turbo
Man is your car a 6th Gen???
Old May 12, 2007 | 09:11 PM
xoomer.com's Avatar
I Donate! Why Don't You?
****. I had my AC compressor changed by the dealer cause the original was fried and I couldn't really check whether it works cause it was brick here in NY. This week was actually "hot" and I just found out my AC isn't working, the air blows but its not cold. Back to the dealer on Tuesday.
Old May 13, 2007 | 01:17 PM
well i personaly used to have a 93 SE. tranny died so i got a accord for a while. but yea we have a 04. older bro. also have a 4th gen also. maxima's all around.
Old May 13, 2007 | 01:18 PM
good luck with that. hope they dont charge you a ton.
Old May 16, 2007 | 08:01 PM
minsbang's Avatar
We found the leak. $250 to replace the part, and recharge// not a bad deal.
Old May 16, 2007 | 09:31 PM
yea i think i am better off doing this at home. get the hose for about 90ish. hopefully that includes the O rings. and new refigerend. cant be more then 130.
Old May 17, 2007 | 07:49 AM
xoomer.com's Avatar
UPDATE to #15.
Got my maxie yesterday and the dealer replaced the hose on the low pressure side. AC working fine now. Work done under extended warranty. $0.00 out of packet.
Old May 17, 2007 | 09:53 AM
Roymg's Avatar
Fantastic!!!!you mean they actually honor those extended warantees? Ha, I got one myself.
Old May 18, 2007 | 12:53 AM
ohh mann your soo lucky. so this is kinda like a known problem. or at lest its starting to be common.
Old May 18, 2007 | 09:07 PM
serenity97's Avatar
A/C hose replacement $$$$$$$$$
I bought my 2004 SE with 71,000 miles on it in January 2007. I didn't notice until it started getting hot outside that my AC didnt work (Blowing Hot). I took it to the Nissan service department and they informed me it was my AC hose that needed replacing. The master technician said that he found this to be a common problem on these cars. The dealership quoted me a price of $450!!!!!!! I thought the certified car care warranty I had would cover this but apparently it does not according to the service department. I traded in my 97se with 303,000 miles on it for this car. I never had a problem with anything related to the AC on my 97!! Maybe nissan needs to do a recall on this part because paying $450 at the dealership for the AC hose is crazy, the car is not that old!!!
Old May 19, 2007 | 07:03 AM
Apollos2's Avatar
I had my low pressure hose replaced last year at about 25k miles. South if you do this yourself, take a lot of pics, step by step and maybe it can become a sticky since so many have had this problem and the dealer wants so darn much to fix it.
Old May 19, 2007 | 03:52 PM
hondadude's Avatar
I do agree, $450 for a stinking hose is highway robbery.
But if it is a Nissan specific part, what can you do?
Old May 19, 2007 | 04:38 PM
SuperMario's Avatar
Is this really a Nissan specific part? From reading some posts above, I understood some non-oem hoses are available...maybe I understood wrong. If not, please specify.
I agree with posting a replacement hose STICKY with lots of pictures...
Old May 20, 2007 | 02:25 PM
I was wondering if this was a specific part too before i had mine replaced since I've been told that some shops can make A/C hoses themselves. The shop I went to had to buy the hose from Nissan for ~$110 I think. The hose seems unique to me because it has metal piping on both sides of the rubber hose and one side has the low side schreader valve built into it.
It seems very odd that so many hoses are going this early. I wonder what supplier/factory f....d this up.
Old May 20, 2007 | 06:36 PM
xoomer.com's Avatar
With these many people chiming in with the same problem it would appear that this problem is somewhat common. I love this car, but think anyone else would have given up on it after so many dealer visits.
Old May 21, 2007 | 05:07 PM
all do. shoping around rite now for some prices.
Old May 21, 2007 | 05:10 PM
goshn(sp) the cost cutter. new wave of cars should have much better quality.
Old Apr 23, 2008 | 02:37 PM
erdnl's Avatar
CALL 1-800-647-7261...NISSAN CORPORATE. PRESS OPTION 7 THEN OPTION 4. THE MORE PEOPLE COMPLAIN ABOUT THE SAME ITEM, THE MORE LIKELY THERE WILL BE A RECALL!! FREE REPAIRS!!
Old Apr 23, 2008 | 02:56 PM
whitem1ke88's Avatar
This thread is a year old, why does nobody look at the dates? If his hose isn't fixed yet, he's not gonna do it.
Old Apr 23, 2008 | 03:00 PM
erdnl's Avatar
Old Apr 23, 2008 | 03:23 PM
erdnl's Avatar
Sorry--You're right--I didn't look at the date. I got so flustered at this stupid repetitive problem that when I saw others had it, I wanted to spread the information that Nissan Corp gave me. Regardless of how long ago the problem is, it doesn’t hurt to report it to Nissan—it could help others and it may just make Nissan put out a recall.
Old Apr 26, 2008 | 05:36 PM
saraara's Avatar
I found the leak at the area where it says 04/16/2008, check 1st picture in bellow thread. Yes exact the same small spot what OP has in his 1st thread.
http://forums.maxima.org/showthread.php?t=559675
Thanks to GrimMax, I had to use one of your picture to illustrate proper leak area.
Old Jan 30, 2009 | 09:30 AM
bratch's Avatar
I know this thread is old, just adding to the collection. 2006 Maxima SE 50k miles has same exact problem with the low pressure AC hose. 2 years ago the dealer replaced the high pressure line under warranty, now they want $439 ($110 part, labor, and recharge) to replace the low pressure hose. Extended warranty is through credit union, but I'm taking it somewhere else to have the work done. I still do not see a recall for this issue. Better keep my receipts for this close by.
Old Jan 30, 2009 | 05:46 PM
Talon05's Avatar
I got mine done for 245.00 at a local shop. I have an 2005 wit 97k miles, dealer wanted 435.00 I said no way
Old Apr 14, 2009 | 06:48 PM
bored's Avatar
2004 SE Same problem...
Old Apr 14, 2009 | 07:14 PM
Apollos2's Avatar
I've had mine replaced twice under warranty and now my tech just informed me its leaking again :-( This one will be on my dime. Cheap A/C hoses or something.
Old Apr 14, 2009 | 08:29 PM
bored's Avatar
does anyone know if there is an aftermarket replacement that is of better quality than the oem one?
