4th gen 3.5 swap compression
02+ VQ35DE's all have 10.3:1 if they're healthy. IIRC, earlyVQ35(01) Pathy's had 10.0:1. But that's another story.
Unless you interchange heads from the VQ30DE, there wont be any changes.
225? you must have alot of carbon on those piston rings to have that high of a compression. The highest my engine does is 210psi, same with others maximas that I've been there for the compression check.
Originally Posted by 95BLKMAX
same specs as 3.0. 180psi minimum.
Either way, as you know, the absolute numbers aren't as important as variance between cylinders.
Fakie J Farkerton
Oct 14, 2015 06:25 PM
Finkle
Sep 27, 2015 09:53 PM
ViciousVQ30
Aug 5, 2015 05:40 PM
I thought that's what you meant, just thought I'd throw that out there for sharts and gangles.
