Misfire... help please
Well... unbeknown to me... after cleaning out my intake filter... when i was going to work the next morning (2 dayz ago)... my car startz misfiring. wats the first thing i should check/change???
-this morning while driving to work... my engine light and emergency brake lights just came on by themselves.... but car iz running "ok" besides the misfiring.
need some help on this... my first guess was spark plugs and coil pack...
any suggestions as to what i should do first??
I just had a similar problem...
I found out cylinder 3 was mis firing, so I replaced the plug, marked and swapped the coil from cylinder 3 with the coil in cylinder 1 and it started and has been running fine...
I figure it was the plug, but if it was the coil I will find out soon enough, and if cylinder 1 is misfiring I know it is that specific coil for sure... and not electrical connection or something stupid like that...
Good luck
its a good place to start...
took me 15 mins...
I figure the cost of the plug is not worth the time to do the job twice if it turns out to be the plug..
Dave
Good luck
took me 15 mins...
Dave
It turned out the plug was not the problem, and I just replace the coil that was in cylinder 3, and it seems to be working fine now...
The Idle changed whin I pulled the bad coil, but once replaced the car seems to run good now, although it has only been a day, I am going to give it a week or so, before I determine that its a fix, cus replacing the plug fixed it for a day last time, so will see.....
GL all
Just pull the coil while running. If the idle doesn't get worse, change the coil.
GL all
alanfury75
Jun 10, 2014 10:59 AM
MAXIMA_STYLE
Sep 10, 2012 05:53 PM
TibTibs
21
Apr 28, 2012 09:58 PM
