q45 tb on vq35?
q45 tb on vq35?
i was thinking about installing a q45 tb on my car, because there is one at a junkyard near by. i was also going to do the 3" maf.i searched and read that you cant install one on a usim or mevi, because it would be too large to match the im. is that the same case with the 3.5 im?
If I were going to upgrade the TB size, I would use this thing, and convert it to DBW.
http://cgi.ebay.com/ebaymotors/75MM-...19267193QQrdZ1
Originally Posted by NmexMAX
Q45 TB = 90mm.
PF/FWDVQ35 TB = 70mm
Port will be too small. Not sure about bolt pattern.
I've got two of those Q45 TBs for a future project. Yes, the bore is 90mm and No, the bolt pattern is much wider than Pathy 70mm TB.
They are BIG, but of no use unless you are moving a lot of air into your motor. If you're NA, a Q45 is pointless.
Granted, they have a nice throttle cable attachement, but.........
