Burning smell, some white smoke from under the hood
AC Compressor motor is slipping ... Belt loose? (Photo uploaded)
I'm kinda a noob when it comes to car. But ...
When I was driving down an express way, about 50 - 55 mph, I noticed a burning smell from the AC vent. Then, about 10 seconds later, I see little white smoke coming up from under the hood. Panicked, I pulled over.
Here's the scene. I see little white smoke rising from under the motor belt, to the left of the hood. I have not had this problem ever before. I'm still smelling the burning smell, but not smoke ... Should I replace the belt, and probably oil change?
How much would it cost to replace the belt? It's kinda hot here in DC lately and I think something might be burning soon. Should I continue driving it or should I have it look at first?
Help or advice is much appreciated.
Ok, I know what the problem is ... how can I fix it.
It seems that when the belt rotate, what looks like my AC compressor does not move. Or rather, it keeps slipping ... Lose belt? How can I adjust a lose belt? ...
The round motor on the image is the one that is slipping. Picture is taken from under ... Any idea?
I'd remove the belt and make sure the compressor spins freely by hand first. you have more than a loose belt going on...... Read the stickys or fsm for belt adjustment info, Hint: you will need a 14mm wrench and socket.
yes, the clutch assembly (pulley + triangular looking thing) should always be rotating, but the actual a/c compressor does not always rotate. Does the pulley not rotate with the engine running? In the maintenance faq you will find instructions for replacing the bearing
Still append to the question, the motor on the image, the one that's in focus, closest ... Is it the AC compressor? I read the Haynes Manual and they said it's the AC compressor ... If it is, is it supposed to spin all the time, together with the belt?
Thanks KRRZ350 ... the pulley is rotating ... just the AC compressor motor slips ... I mean, it looks like it's rotating but very very slowly ... Agg ... I will post video if that helps ... ^^ Anyway, I'm taking a bus tomorrow to work. Lolz ... don't have time to work on it till Wednesday.
Hope that helps
Uhm ... jellyfishian ... if that's the case ... with that many friction ... should it starts to burn the belt out? ... Cuz I was smelling something burning under there, and it sure smells like rubber burning ...
There is a ring that rotates around the A/C compressor when its not on so the belt still spins freely.. If that is locked up on your car I would assume the belt would be torn up very quickly.. Here is what the compressor should look like: http://media.putfile.com/ac-compressor-fixed about half way through the video the compressor engages.
Uhm ... jellyfishian ... My AC compressor does not stay still before it's engaged like that in the video ... Rather, it kinda spins slowly now and then ... looks like it's slipping. This happen when the AC is not on. I'm gonna run home after work and see what happen when I engaged the AC compressor. Probably, I'll post video too.
Thanks man
Thanks man
Update on the Original problem:
I got 2 burnt fuses ... One is for the AC that's 7.5 and one is for the Fog Light 15 (No wonder why my fog lights haven't been working .... duh) Fusible Link box next to the battery ...
But still, how does that contribute to burning smell from under the serpentine belt .... I still can't figure it out ....
