How to route wires through the firewall?
Old May 14, 2007 | 05:41 PM
maxout!'s Avatar
It's a 06 max and I wanted to route some wires through the firewall. anyone knows how to do this easily without any major disassembly? thx a mill
Old May 14, 2007 | 09:06 PM
Omarvelous's Avatar
yea i'd like to know as well... will be running r 1/0ga through soon.
MaxChef should know.
Old May 15, 2007 | 07:37 AM
xoomer.com's Avatar
I Donate! Why Don't You?
I had the power my amp done and there is a cable already going through it so they just removed the rubber groomet and fed it through there. No drilling required. My maxie is in for service but when it comes back I can snap a pic.
When you pop the hood just stand on the driver's side and look down at the firewall and you'll see it. You can't miss it.
Old May 15, 2007 | 07:42 AM
Blulytes's Avatar
Or you can just drill your own hole though.
I did it in the same area, 1" around.
Old May 15, 2007 | 08:23 AM
chernmax's Avatar
Nations 1st 6th Gen Turbo
I found a pass through for wires that I ran my Halo's pwr switch through on the drivers side. Using a flashlight, get under the drivers side console and look up in the area of where your dead peddle would go on the firewall, Its in that area. It should also be visible from behind and just below the brake fluid reservoir...
Old May 16, 2007 | 11:08 AM
Licken2's Avatar
There's a rubber grommet in the passenger side firewall. If you look up behind the glovebox, you'll see a harness going thru it already. There's plenty of room there to get a power wire through. I ran 4g w/ no problems.
Old May 16, 2007 | 06:29 PM
Apollos2's Avatar
Here is where mine went:
A little closer
Old May 18, 2007 | 10:01 AM
Omarvelous's Avatar
A little closer
was that stock or diy?
Will be running 2 runs of 1/0ga, so i'll look at all ur guys tips today n see.
Old May 18, 2007 | 10:20 AM
chernmax's Avatar
A little closer
That's where mine is also...
Old May 18, 2007 | 11:07 AM
Blulytes's Avatar
me too!!!!
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
