Hub centering rings, does one brand fit all?
I currently have HP wheels with hub centering rings on my 98 maxima. I am switching to Axis wheels. The wheels I am buying do not come with centering rings. I am wondering if I can use the centering rings on my HP wheels on the Axis wheels or do I need to get a new centering ring since the center bores on the wheels may be different (I'm not sure if they are or not). If I need new ones does anyone know the best place to get some axis centering rings quickly? Thanks for any help.
ok so it sounds like I can use the rings on my HPs. Next question is, should I just stick with the plastic ones that came with my HPs or would a metal ring be better and where would I buy those? There are really no "tuner" shops in the area so it would be something that I would probably need to get online. Thanks for the help.
Check ebay first, then go to google.
well if anyone else is wondering the samething I did. I finally figured it out. The center bore on my fourth gen is 66mm and the hub bore on the axis (I may add this is most wheels) is 73.1mm, so I needed a 66->73.1 hubcentric rings. I some metal rings yesterday on ebay from discount tire.
maxfever1987
Sep 6, 2015 06:20 PM
