firewall question
Old May 18, 2007 | 07:41 AM
max2moon17
firewall question
i am trying to put my bumper neon wire through my firewall, but i wanted to ask you guys first on how to do it.
Old May 18, 2007 | 07:56 AM
D-Twelve's Avatar
Got some good advice from studman.
"I ended up getting the wire through the same hole as the hood release cable...I stuck a screwdriver through the rubber boot/grommet from under the dash, duct taped the wire to the screwdriver, and pulled the wire through from inside the fender well."
Old May 18, 2007 | 08:01 AM
max2moon17
thanks man, but is there any other holes?
Old May 18, 2007 | 08:03 AM
speed racer's Avatar
That is the most common. If you need another hole the best thing you can do is drill one in that same location. Start with a small drill bit for metal and gradually use bigger bits to suit the size you want.
Old May 18, 2007 | 08:10 AM
max2moon17
thanks then i would have to put silicone around the hole right?
Old May 18, 2007 | 08:28 AM
if you want. I didn't
Old May 18, 2007 | 09:18 AM
f550maranello2's Avatar
at least ure a rubber grommet.. so u dont cut the wire if u tug on it... dont it once do it right....
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
