Sponsored by:
Sponsored by: CARiD
eu install and tuning questions
Old Jun 11, 2007 | 10:58 AM
MAXSE5SPD's Avatar
i have had an eu waiting to be installed for months and now i finally have the time to do it. im going to make a plug and play harness like what goaliekeg did. i have a fried ecu for the male connector and 2 ecu plugs for the female connector. first, how do i remove the male connector from the ecu mother board w/o damaging it?
second, what are the type of pin connectors that are used on the ecu plug?
also, i know that i need to get a wideband, but im poor at the moment. can you get a decent tune using the o2 sensors, or would i be wasting my time?
Old Jun 11, 2007 | 11:08 AM
DandyMax's Avatar
3.5 in the works
You'll have to unsolder the connector off the board (use soldering iron and solder sucker etc)..
It's a waste of time trying to use the stock narrowband sensors to tune. They cannot tell you what your AFR is unless it's VERY close to stoich (14.7), which obviously you don't want under WOT.
Old Jun 11, 2007 | 11:09 AM
MAXSE5SPD's Avatar
ok, so basically start saving my pennies if i wanna tune with a s***.
Old Jun 13, 2007 | 07:49 AM
Puppetmaster's Avatar
I just cut it off with a tapered head wire cutter....
Old Jun 13, 2007 | 08:04 AM
DandyMax's Avatar
3.5 in the works
Hmm yeah I suppose that could work well enough for the purpose the connector will be used for... (didn't really think about the intended use, just gave the standard method)
If it needed to go back on another board though then different story.
Cotozic
Jun 28, 2017 08:01 PM
Finkle
Sep 27, 2015 09:53 PM
t6378tp
Aug 24, 2015 07:03 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
DayHeyZeus
Garage and Workshop
Aug 16, 2015 12:29 AM
