help::temperature gauge inside is going out
is there an DIY how to fix the temperature gauge? when i hit the dashboard needle will either go all the way up.. or normal.. or just look dead.. coudl it be a bad solder? HELP PLEASE =)
There are causes for this that aren't cluster related. In my case, changing out the cluster solved my problem. The old one probably just needed some solder, but they are only about $10 at the boneyard so I took the easy way out.
hehe....mine has been like that for a year...it works and dosent, mine turns off/on when i switch gears....but for the majority of the time stays on..if it completely is stayin off fix it, but if it is only once in a blue moon you mite be ok IMO
http://forums.maxima.org/showthread.php?t=522594 i had a similar problem. Opening up the throttle caused enough vibration from the engine to wiggle the connector's metal tab loose... which meant it contacted at times but not at others. I went to a JY, got another temp sender, problem solved.
for VG owners with this problem (unless the VE part is the same as well): if possible pull one of an '89. The design is more durable IMO, than the one that was OE on my '90.
Mine started to do this as well recently. Mine will just drop all the way down. I think it's an air bubble though because it seems to change with elevation. I live at sea level and when ever I drive out to my grandparents house it's like it drops at the same spot every time I go there.
litch
123
Jan 4, 2024 07:01 PM
tarun900
19
Dec 20, 2021 06:57 PM
AaronL
Aug 8, 2020 10:31 AM
RWCreative
Sep 21, 2015 11:01 AM
