odd cold start and oil level sensor problems
Old Jun 13, 2007 | 05:06 PM
MAXSE5SPD's Avatar
when the car has been sitting and is cooled off, ill start the car, then when i go to take off, the car stumbles badly for about 3 seconds, then is ok from then on. it revs fine, its just when the car is in gear and i am attempting to pull away. it doesnt do it on hot starts or any other time when driving.
also, i noticed something dangling under my car. it was the wiring for the oil level sensor, if thats the name for the sensor that mount by the oil filter facing the back of the car. im sure all my axle installs and uninstalls beat the **** outta that harness. will that cause any problems? i dont have a code for it right now.
Old Jun 13, 2007 | 05:18 PM
pmohr's Avatar
No more Maximas...
Are they cold starts as in the temp gauge is actually pegged below C, or just that it's been sitting for a few hours?
That's the oil pressure switch, we don't have a level sensor. The only problem that it'll cause is you won't know when you've lost oil pressure. With that VQ35 drinking oil, that may be an issue
But basically, you won't know if/when you lose oil pressure. No biggie if the motor actually has oil in it, and you aren't revving the **** out of it (like, 9 grand or thereabouts, where the oil pump grenades and kills all those around you).
Old Jun 13, 2007 | 05:19 PM
MAXSE5SPD's Avatar
pegged.......
Old Jun 13, 2007 | 05:46 PM
pmohr's Avatar
No more Maximas...
Originally Posted by MAXSE5SPD
pegged.......
I don't remember your specifics as far as the 3.5 swap goes, you don't happen to have a wideband and some sort of engine management, do you?
Old Jun 13, 2007 | 05:48 PM
MAXSE5SPD's Avatar
nope. i got an eu, but not installed. im trying to remember, but i dont think i had this problem when i was a 5spd.
homeyclaus
Sep 3, 2015 06:15 PM
FlaMark
Aug 21, 2015 11:06 AM
maxinout93
Aug 20, 2015 02:17 AM
Balkins
Aug 12, 2015 06:39 AM
Max Nu-BE
Aug 11, 2015 06:34 PM
