Cabin air filter replacement
Old Jul 2, 2007 | 05:40 PM
SuperMario's Avatar
I didn't find a sticky or instructions on changing a 6th generation cabin air filter.
Has anybody changed it? Any instructions, perhaps pictures on changing this filter?
Old Jul 2, 2007 | 06:13 PM
!PrjctMax!'s Avatar
2 clips on the bottom of your glove compartment-take them out, the left one goes out right and the right one goes out left
let your glove box "hang" gently and now you see the panel to remove for the filter-REMOVE it using common sense and swap the filter out, re-install everything in reverse order and you are done!
dan
Old Jul 2, 2007 | 08:14 PM
Ritz's Avatar
pretty much what he said... I took the retracting cable off to take the glove box out completely though.. it's really pretty simple.
Old Jul 3, 2007 | 12:58 AM
MiamiBlackMax's Avatar
if anything use the manule...i think it was in section 8 or 9 pretty much tells you there..hardest part is takin off the 2 clips to take of the filter
Old Jul 3, 2007 | 05:02 PM
Longhorn101's Avatar
and do yourself a favor and pop those two clips to the air filter box with a small, regular screw driver or something similar. I got some good cuts the first time by doing it by hand. Once you've done it once, it takes all of 3 minutes for the complete job.
Old Jul 3, 2007 | 07:59 PM
i agree w/ longhorn i tried opening it and after 3 times i said f@# it and just a small screw driver..wish i thought of it from the get go makes it much easier
Old Jul 3, 2007 | 08:28 PM
thecritik's Avatar
I think the clips were the easiest part. The bungee cord was the hardest and figuring out which way the ****ty filter went in. I got it from the dealership and it was completely different from the one that was there. So much for stocking OEM parts huh?
Old Jul 3, 2007 | 11:02 PM
jsmithsole's Avatar
*moderator*
Changing it is a good idea I waited for 2.5 years and here's what came out...
Old Jul 4, 2007 | 03:16 PM
04BlackMaxx's Avatar
Hate to say it, for the pain in the *** it was getting at, I dont notice any change in the air inside the cabin..
Old Jul 5, 2007 | 07:40 AM
S_Klass's Avatar
Was yours pretty clean or filthy when you took the old one out?
Old Jul 5, 2007 | 07:47 AM
SilverMaxima06's Avatar
How often do you have to change this? 15k miles? 30k miles? Or is this time based vs miles based.
thanks!
Old Jul 5, 2007 | 09:05 AM
S_Klass's Avatar
thanks!
Officially every 30K miles IIRC.
Old Jul 5, 2007 | 09:53 AM
ecks's Avatar
I piss on Civics.
i took mine out at 16k just for the heck of it thinking it would be somewhat ok to leave it in. Oddly enough it was as dark as jay's if not darker!
Old Jul 5, 2007 | 10:25 AM
S_Klass's Avatar
It'll have a lot to do with how dirty/polluted the air is around where you drive most often.
Old Jul 5, 2007 | 11:35 AM
It was, 60,000 miles were on it
Old Jul 5, 2007 | 11:41 AM
xoomer.com's Avatar
I Donate! Why Don't You?
Change every spring for best performance. Lots of dust is collected furing summer/fall months and moisture sets in during fall/winter months sometimes causing a bad smell. If you don't drive much, change two years. If you do 15-20 k, i would change every year. They are less then $10.00 and it takes 10 minutes to change, well less if you don't talk much.
Old Jul 5, 2007 | 01:16 PM
Fastmax05's Avatar
"Ok,Whats next?!?!"
doing this today... we will see how dirty the air REALLY is here in Los angeles hahaha
Old Jul 5, 2007 | 02:47 PM
S_Klass's Avatar
HA I bet it'll be filthy. That's what sucks about living in most of So. CAL - the air is pretty bad.
Old Jul 5, 2007 | 04:01 PM
DeusExMaxima's Avatar
I just called the stealership. They want $35 for the filter. Where do u get it for $10?
Old Jul 5, 2007 | 04:15 PM
And then I called my local auto parts place - $12!!! Woohoo. Ill get mine tomorrow and have it in as well. Pics to follow.
Old Jul 5, 2007 | 04:28 PM
I believe Advanced carries a Purolator replacement for ~$12. It seems to function just fine.
Old Jul 5, 2007 | 05:11 PM
Carmax07's Avatar
Don't get replacement at dealership, get online or at auto parts store and it works just as good...
Old Jul 5, 2007 | 09:01 PM
Fastmax05's Avatar
"Ok,Whats next?!?!"
GOOD GOD@!!! mine was nasty... ill post pics soon... wow... im still coughing
Old Jul 7, 2007 | 01:57 AM
ThunderMaxi's Avatar
I need to do this... Hi-Lo out here wanted $25 for it... I will have to look for another place ot get it at.
Old Jul 7, 2007 | 08:42 AM
SuperMario's Avatar
OK Fastmax, go ahead and post instruction pics, make it a sticky!!!!!
Old Jul 7, 2007 | 02:47 PM
Fastmax05's Avatar
"Ok,Whats next?!?!"
word man... but its going to be a few days now... i went to napa autoparts here in so cal and they want 27.94 plus tax for it!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
where can i get it online for less??? guys??????
Old Jul 7, 2007 | 04:00 PM
MAJ_Jimbo's Avatar
How about Advance Auto Parts (if you have one), for 12.28? It's a Purculator C35530....
Jimbo
Old Jul 8, 2007 | 01:36 AM
Fastmax05's Avatar
"Ok,Whats next?!?!"
no advance... we have autozone napa pep boys kragen
Old Jul 9, 2007 | 09:11 PM
I just did mine. Im glad I did:
Old Jul 9, 2007 | 09:25 PM
S_Klass's Avatar
Hot damn that's filthy!
Old Jul 9, 2007 | 09:51 PM
vir420's Avatar
Wow, I don't know even knwo if I should post a pic of my filter when I replace it, due to the fact that I'm sitting at 84K right now
Old Jul 10, 2007 | 12:35 AM
Fastmax05's Avatar
"Ok,Whats next?!?!"
dues yours takes the cake man... its cause we are in cali hahah mine was close to this hahah not hat bad
Old Jul 10, 2007 | 10:33 AM
Mine is probably bad because of the racing I did in Lone Pine. My car has 55,000 miles on it and never has been changed. I didnt notice any difference this morning when I turned the air on.
Old Jul 10, 2007 | 10:47 AM
Fastmax05's Avatar
"Ok,Whats next?!?!"
your lungs notice and say "THANK YOU" ahahah im sure you will find less dirty on the inside of yoru car tooo... along dash etc...
Old Jul 10, 2007 | 10:49 AM
xoomer.com's Avatar
...and the winner of the dirtiest micro filter contect goes to...drumroll....DEUS!!!
Old Jul 10, 2007 | 10:52 AM
Smoke_Screen's Avatar
JFK Deus! That's friggin dirty! Anyone got a pic of where the clips are you have to unlatch your glove box?? Thanks
Old Jul 10, 2007 | 11:32 AM
Fastmax05's Avatar
"Ok,Whats next?!?!"
just open your glove box and look... its right there man ... u cant miss it...
i hope....
Old Jul 10, 2007 | 11:50 AM
Yeah, I was gonna take pics but its so obvious. Check your owners manual. The hinge pins are right under the glove box door too.
Old Jul 10, 2007 | 12:14 PM
Fastmax05's Avatar
"Ok,Whats next?!?!"
yep... took me no more than 90 seconds... in and out...
Old Jul 10, 2007 | 03:16 PM
Apollos2's Avatar
I gotta change mine again. You can get em for $10 shipped right here on the .org http://forums.maxima.org/showthread.php?t=518370 I just ordered 3 of them.
