for those of you that have done brembo rotors/brakes help!
what are my options guys? I have two rear calipers in need of replacement totaling about $400 bucks. So I said to myself I might as well just upgrade my brakes. But the big brake kit is just the front calipers and rotors and requires a 17 inch rim correct? this would be no good then cause I switch back to my stock rims in the winter and I think the kit runs $2500 roughly and doesn't include the rear calipers which is what I need. If I do just the Brembo rotors and pads from the group deal I still need to buy two rear stock calipers. Are you guys that are going with just the rotor and pad upgrade using these with stock calipers? Im undecided on what I should do. Does anyone know if Brembo rotors and pads are a direct replacement for the stock rotors? Will they work well with stock calipers and accomedate the stock "16 rims?
If I do these Brembo crossed drilled (I like the look of crossed drilled) rotors and pads what other caliper upgrade options do I have without major modification? I would appreciate anyfeed back guys.
I'm completely re-doing my rear brakes, rebuilt calipers, new rotors, hawk pads, new lines... total cost is going to be about $150. How in the world are you spending $400?
What kit are you talking about? Are you refering to the brembo calipers from a 350z track edition?
Most people on here use the Z32 calipers with 13" cobra rotors, that requires a 17" wheel. If you want to be able to use a 16" wheel, I think you can use the stock Z32 rotors and calipers. The stock rotors are small enough to fit in a 16" wheel.
Don't bother with the big brake kit unless u track your car a lot. Just go with the brembo blank rotors and hawk hps pads all around. Most people love them, including me. Provides better stopping power than stock and does not cost too much.
About calipers: Don't buy them from nissan for $260 each. Just go to Autozone or Advance autoparts to buy them like I did. Costs around ~$100 each for unloaded caliper after a core return-which is a lot less than courtesy nissan.
p/s: I just checked tirerack on blank brembos and hawk hps pads and for all four corners -they cost $276 plus s&h
two calipers= ~$200 ish
total cost around $500 if you do the job yourself. Then change the brake fluid and ENJOY the hawk/brembo combo stopping power
Hope this helps
Hope this helps
Originally Posted by maxprivate
how in the world are you doing all that for $150 ? for just the nissan oem calipers its $260 each from courtesy nissan and its a rebuilt caliper. i called today and thats the quote i got. and to speed racer whats that supposed to be a joke?
Hope this helps
Hope this helps
what about the dust backing plate will these brembo rotors clear them?. and yes i will stay away from the big break kit do to the fact that i use my stock rims in the winter.
so basically you can use any of the brembo rotors with stock calipers ie, crossed drilled,slotted or blank? and thank this is very helpful. to vip maxima i was simply shopping aroung for a price out of curiosity.
I currently have slotted brembo rotors on the front and blank brembos on the rears + hawk hps all around. I got slotted ones for the fronts because most of the stopping power comes from front brakes. Moreover, I like the look of the slotted rotors too.
So far, I've been on them for about 3 month/5000 miles and I am happy with the results. I even did autox few times... Well spent money.
Originally Posted by VIP Maxima
its 2008 and i still dont understand why people go to dealerships for parts
i went on ebay about a month ago and bought 2 front calipers from there for 100 (the rears are a bit more but def not 240 a piece) and boughtr the crossdrilled brembos from the group deal from jeff - i suggest you do the same
i go to the dealership for parts all the time. Its not ALL expensive.
and to the OP, i bought some nissan pads and brembo blanks for the front...no modification needed
. i am thinking about getting some SS lines though, the brake pedal doesnt have the feel that i like.
LOL at this thread because a $300 caliper fix somehow evolves into buying a $2500 brake kit.
Be careful mixing and matching brake kits. Usually, a bigger set in front is safe but not optimal. If you put bigger brakes or higher-friction pads in back without upgrading the fronts also - you can end up with rears that lock the wheels before the fronts. This is a dangerous condition that will cause you to spin if you lock the wheels on braking.
Dave
Originally Posted by dgeesaman
Yeah, really it would have been bad enough for this to happen back in good-ol '07.
Dave
Dave
Yes, you can use any stock replacement brembo rotors whether it is blank, cross drilled or slotted. I personally like slotted ones because the structural strenth of the rotor is better than x drilled.
an auto tech i know at nissan told me dont bother with the break lines unless yours are shot. just to let you know. did you have to remove the dust plate? or does the rotor fit right in place of the stock one?
You are associating the word 'Brembo' with performance, which you should not do. Brembo is a company that makes brake components for both OEM (orginal equipment manufactures) as well as aftermarket upgrades. If you purchase brembo rear rotors for your Maxima, they are going to be the EXACT same size as stock, there will be no need to trim the dust shields, because they are exactly the same. Brembo does not make a rear big brake kit for the Maxima, only that would require trimming of the dust shields.
You are making all of this WAY too complicated on yourself.
The day you start listening to most techs at a Nissan dealership is the day you should just shoot yourself. Most of them can BARELY accomplish there basic jobs on a daily basis, do not ask them any questions when it comes to performance parts. Period.
As I said in a previous post stay away from brembo big brakes kits unless you have deep pockets. At most the rotors can be turned once and all replacement parts are very expensive.
Don't get me wrong, they are great brakes but they are a mod that screams if you want to play you've got to pay!!
I'm still wondering how you know your rear calipers are going. Are they seized? If you know that your rear brake needs replacing and with the budget you have there should be no question, to get whats broken fixed first.
correct on that mark, i know the rear caliper is bad cause it seizes up at times and makes a horrible noise while im driving. also the rotor is over heating do to the caliper not releasing when it should,this is causing a huge discoloration on the rotor.
The Autozones are rebuilt/refurbish calipers. We use them at my shop and so far no complaints. It does its job without hurting the wallet when compared to other places (ie dealerships). The cross drilled are not necessary for DD, with the brake pads today they do pretty well dealing with brake fade. They are mostly cosmetic unless you track your car, its just something I would not compromise in the structural integrity of the rotors for show.
And if you want to save yourself a buck the Duralast rotors (Autozone, costs about ~20) are a good alternative to the Brembo blanks. I've tracked both and its no difference. Both needed to be changed after a hard track session.
If they are truly the Brembo slotted and not the rebranded or drilled/slotted from blanks it should be fine. Those that are more suspicious to cracking are those that are altered from blanks. As I've said before, they are purely cosmetics. The Duralast does the same job but cost less. In the end its your money so its up to you. You'll need to bleed the brakes when taking out and replacing the calipers. Taking off the lines and bolts are much easier than bleeding the brakes for me. Good luck.
What is your driving habit like? What are you priorities? Do you do a lot of hard brakes? What is your environment like, cold, warm or hot weather? What is your budget like?
I suggest the Akebono ProAct, since warm up time isn't much of a concern for you but more of a noise/dust factor.
dust plate left installed with brembo xdrilled or slotted rotors
to those that have the brembo slotted or xdrilled rotors,are you leaving the dust disk plate in place? i was just curious to see what others are doing or if it is even needed at all with the brembo xdrilled or slotted rotors. any one have pics of theres installed with out this dust plate?
I just replaced my rear calipers, rotors and pads on monday. MY pads had worn down and were grinding on the rotors so I had bought some pads off of the .org and got some rotors from autozone. When I went to replace them, I foudn out the piston was seized and needed new calipers. The calipers cost $145 each from the local dealer through the shop and they installed them with the new rotors and pads for $400. Not really that bad of a price for something so important to safety.
Apr 16, 2020 05:15 AM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
maxima_dumby
Mar 21, 2002 10:45 PM
PRINCE NISMO
Sep 28, 2001 10:19 AM
MaxTuner
Jul 30, 2001 03:47 AM
