My clutch is toast!!
So as the title says, my clutch is toast, what do u guys recommend? I get the feeling most people would recommend going with the 5th gen clutch set up? What are the benefits or draw backs from using this set up? if not the 5th gen clutch, then what clutch would be best? thanks in advanced guys....
Originally Posted by Vlasic
Get a 5th gen setup, stronger than the 4th gen, no draw backs to it. If your not boosted or on nitrous there is no reason to get anything stronger than OEM.
Where from? Where do they have it the cheapest? And What are all the parts i would need, so i don't leave anything out?? Also, when changing or replacing tranny gear oil, how much quarts should u replace it with?
Trans takes about 4.7qts I think. Just fill it until you can feel that tehre is oil at the top of the fill hole. You can order form these guys, they are pretty cheap, or you can order from DaveB who is a member on here and I think a parts guy at a dealer (Ive never used him but people say he is good). As for parts you need the 5th gen disk, preasure plate and throw out bearing. Also if you are doing this yourself and dont have a clutch alignment tool, you will need one of those too. I dont know the parts numbers for all that stuff off hand, they are in a thread from a while back, you will just have to search for it. I think there is only one PP and TO bearing for the 00-01, but there are two disks.
carlosvq30
Sep 26, 2015 09:44 AM
