FS: 4th gen trans with cryo'd/detailed gears, new bearings, etc.
Old Jul 12, 2007 | 09:56 PM
Nealoc187's Avatar
SLOW
Just finished this trans up tonight. Highlights of this trans are:
1st gear - cryo treated and detailed 5th gen gear (double synchro as opposed to single synchro as in 95-96 transmissions)
2nd gear - cryo treated and detailed 5th gen gear
3rd gear - detailed 5th gen gear
4th gear - detailed 5th gen gear
Brand new reverse idler gear
Brand new 2nd gear synchro
Brand new 3rd gear synchro
Brand new differential carrier bearings (aka side bearings)
Brand new input shaft bearings
Brand new input shaft seal
Brand new striking rod seal
Shift rails detailed and polished for smoother shifting
Hubs buffed for smoother shifting
Sleeves buffed for smoother shifting
Shift selectors and fingers detailed and polished for smoother gear changes
Glass beaded transmission case - so clean you could eat off of it
Case oil modded for more oil flow to input shaft front bearing
Properly shimmed to the following specs:
Input shaft: 1.41mm shim used (1.37-1.42mm req'd to be in spec)
Differential: 1.68mm shim used (1.67-1.72mm req'd to be in spec)
Main shaft: 1.23mm shim used (1.18-1.23mm req'd to be in spec)
OK so here's the deal. Will this trans be stronger than a stock 4th gen trans? Yes. Will this transmission be indestructible? Absolutely not - no one can ever guarantee that about any trans. What I can guarantee is that this trans is shimmed properly and that the work above is done to try to make this transmission as strong as possible within the limitations of the tiny, wimpy gears that the manufacturer uses and that the trans should shift incredibly due
Price is $1100 shipped right to your door. I will take care of shipping through Fedex insured ground shipping through my work. PM me. Paypal or cashier's check accepted.
Old Jul 13, 2007 | 06:18 AM
RIPTIDER's Avatar
DIBS, on this one.
what is your paypal account?
Old Jul 13, 2007 | 06:23 AM
RIPTIDER's Avatar
is this open diff or vlsd?
Old Jul 13, 2007 | 09:19 AM
matty's Avatar
Second Dibs. Seriously.
Open or Locking ??
Old Jul 13, 2007 | 05:47 PM
RIPTIDER's Avatar
Payment Sent!!
Old Jul 14, 2007 | 01:11 PM
Nealoc187's Avatar
SLOW
Sold to riptider - I'll have another for sale in the coming weeks.
Old Jul 14, 2007 | 01:15 PM
BlackMaxGTR's Avatar
"DRAG" A game of thousandths
tranny
will it b exact same setup and 1000 cheaper
Old Jul 14, 2007 | 10:41 PM
ashazad's Avatar
trans
i am looking for a non locking transmission, do you have one??
CorollaULEV
30
Aug 9, 2021 08:11 PM
Matt93SE
May 24, 2019 02:58 PM
Maxima_Joe
Nov 25, 2015 08:19 AM
Finkle
Sep 27, 2015 09:53 PM
Hawkeye61
Aug 12, 2015 06:45 PM
