removing c pillars
c pillars
Right!! dont pull the c pils, they crack VERY easy. pop the plastic hold downs from the trunk with the handle of a screwdriver, and from the inside, "bend" the rear deck CAREFULLY and EVEN to get to the speakers.
Umm there is some miss-information here: yes you do need to remove the "c-pillars" behine the rear window, and yeah u CAN use a screw driver to pop the pillar but be very careful, they sit REALLY tight in there and i thought and felt like i was going to break mine, but didn't. have lots of patience with this job and dont skip steps...
The rear seats some out, the rear window pillars come out, the 3rd break light comes out, the rear wool deck comes outas well, everything must go in that order
here is the writeup i used to help me change my rear speakers
http://www.vqpower.com/v2/readarticle.php?article_id=39
thats the one that was in the sticky. that's the one i was referring to. thanks for the input. what other method of removing the c-pillar would you suggest?
EDIT: are they held on by tabs? if so, can you tell me where they are? thanks.
Originally Posted by blimblam
so do i just push up the deck?
well mine did not crack and if u want it done the RIGHT way then u have to remove the pillars, they basically SIT on the rear deck, u can try and fiddle with it if u remove ONE although ure gona have a tough time taking the pillar out of the deck fitting holes. Its a lot easier to remove both, and its not hard at all...
just have a firm grip and pull slowly until they unsnap, dont **** ur pants if u hear some cracking, its the clips coming out of the metal frame, NOT the plastic breaking as maxima985spd suggests.
Just pull. I used a long screw driver on the front bottom edge to get started. Then after that used my fingers to feel behind the plastic for the clips and pull/push. Very easy to do. Just take your time with them.
are there tabs else where that i can press in or something to remove it? or do i just have to pull it out?
The pillars are connected to the car by like 4 little plastic pins. the rear deck is under the pillars. the rear deck also has i think 2 or 3 holes on each side where the pillars slide in. i dont see how u can bend or push on the deck to slide it out without removing the pillars because the deck is connected to the trunk by like 6 plastic pins.
basically do this: remove rear seats, thats easy, then at the rear of the passengers windows take a flat head and carefully untuck the rubber weathering strip that holds the pillar. then with your hand slowly but with good force pull on the pillar from that location close to the window.
One or two pins will unsnap, it WILL sound like u cracked plastic but u will not. then if u have trouble with the rest of the pins under the pillar take the flat head screw driver and pry the pins out. be careful with the seatbelt, there is a stoppper under the pillar...
does that help in any way ? look at the link i provided earlier, its the same way how i did it.
I never removed mine. After popping the 4 clips that held down the rear deck, I put my hand under the card board deck (in the center) and arched it up. After noticing that the deck was held down in the rear corners by the C-pillar tabs, I just loosened up the bottom of the pillars and eased out the deck by pushing down on the corners of it. Make sense?
did you remove the rear seats?
also since we are talking about rear speakers. the maxima i have is a 96 not with bose. came with some small 5x4 i think. can i put a 6x9 speaker in there?
how did u remove the c pillars that u cracked them?
the reason i asked. i already have 6x9's from my older maxima. so thinking of just swaping them over.
so the back seat has to come out.
And yep, the seats gotta come out. The prospect may seem intimidating or tiresome, but it's really not all that bad. It'll be a good learning experience. I'm certainly glad I know how to take my seats out with confidence now. Now it's time for me to figure out how to take my B-pillar off. I've got this rattle under the passenger side B pillar (somewhere in the seat belt harness area) and it's wearing me out.
Oh and check out post 6 for a little guidance on the process. If you don't want to, you don't have to completely take off the pillars. Just loosen up the bottoms for a little wiggle room to get the tabs out of the deck. I also noticed that he pushes up the deck clips from the trunk, but you can just pull up on the deck from the inside and the clips will pop quite easily.
I'm not a huge audiophile so I can't rightfully explain, but sound is better coming from a round speaker, not an oval one.
Wrong, the maxima comes with 6.5" speakers in the rear as well as the front, if u feel like cutting the metal in there u can even fit 8" or 10" subwoofers if u like, but as far as going from 6.5" to 6x9 speakers, there is no point because u will not hear any difference what so ever.
ok. since you claim to be always right on every thing
yeah it can be done if u wanna cut the metal deck a bit, i would suggest not going through this trouble just to put some old speakers in there, what happens if they pop a month later then u gota take everything apart again, might as well do it good the first time no ?
i dunno just from reading your other posts gave me the feeling. sorry if that offended you in any way.
they are not just any old speakers. they happen to be a pair of boston acrustics(sp) and to my ears they sound great. which is why it is worth the trouble. ill just prolly end up dilling new wholes. thanks for the info man.
well yeah it is offensive to tell me that i SAID i know everything because i know i never said that, ask me about turbo, supercharger, nitro, and any of that stuff and im a complete noob... but when i see a thread or a post that i do know something about and especially a thread that has something to do with what i actually did myself then i comment...
anyhow
boston acoustics are a good brand, never heard their car audio stuff but i have heard some home stuff... its more than just drilling 4 new holes.. the rear deck has a round shape cut out to fit the 6.5" speakers, u will need to cut out the sides of that circle to make an oval shape to fit the 6x9's... thinking about it more now it should not be that hard. take a small saw or large metal cutters and take out a triangle on each side of the 6.5" circle, then work from there fitting the new speaker in and cutting a little more every time in order not to make a hole thats too large....
anyhow
btw i just noticed it says u have a 93, i was referring to a 45h gen, not sure about speakers in a 3rd gen... OOOPS
When I replaced my rear speakers I just pried the rear deck up and used a stubby screwdriver to (un)screw the speakers. I didn't touch the C-pillars.
I replaced the crappy Bose speakers with Focal 6.5" components all around (as well as subs in the trunk). They sound awesome. Plus, the crossover for the fronts fits in the plastic Bose amp enclosure in each door. :-)
haha. this awlays gets people. we are actually a maxima familly. i have a 93 se or used to its being parted out rite now. my sister has a 4th gen and my older bro got a 6th gen. but i personally like the 3rd gen and those came with i dont know but i had the boston 6X9's in there. just wanna hand over the whole system to the 4th gen with out the amps tho.
my03maxima
Jul 28, 2024 07:40 AM
RealityCheck
Oct 2, 2015 06:34 PM
