Want to clean my engine bay
Good evening orgers... I want to have my engine bay cleaned, and I was wondering what a safe way was to do it. On my old pontiac, the mechanic I went to just sprayed some engine cleaner on there and then sprayed the entire area with a high pressure hose, and it just didn't seem like the best way to do it given all the electrical connections and parts under there. Another mechanic told me that you should NEVER spray the engine bay with a high pressure hose for the same reasons I felt when my mechanic was doing it. What do you guys suggest?
cool.. thanx guys... according to the other threads theres been some debate about whether or not to use high pressure water.. i think i'll play it safe and just use a garden hose with my finger in it.. so i'll cover up my battery, alternator, intake filter, fuse boxes... anything else?
Originally Posted by soonerfan
yeah, drive it afterwards. the heat will help dry and the movement will prevent water from collecting anywhere
Even if puddles collect, if you drive it a little afterward, those areas I mentioned should dry out rather quickly, so there really is not need to worry about much if anything aside from the obvious (intake)
Originally Posted by wyche89
makes sense... both of you guys have alot of posts, so i assume you know what you're talking about.. lol
Originally Posted by bigEL
These guys, yes. But you can't always tell because a lot of other guys spew cr@p just to boost their post count.
It doesn't matter post count/join date. Knowledge > * .. . Some guys on here know way more than me and haven't been here that long, same goes w/ PC.
Spray with simple green, let soak, rinse, spray with self cleaning tire foam. Ten minutes work and a huge improvement if your engine bay has been neglected. I only use a garden hose, don't cover anything and have never had a problem. I use my shop vac to blow things dry, the air is filtered so there is no chance of blowing a small pebble at your car at 200MPH
Before
After
If you really want it to look good you need to spend a little more time with armor all, metal polish, and a rag.
Before
After
6spd4dsc
Mar 4, 2016 05:19 PM
fastcarny
Oct 6, 2015 10:42 AM
aminus21
Sep 12, 2015 04:53 PM
03VQMAX
Sep 5, 2015 03:47 PM
but I'm moving it to Detailing.
