Front End Noise fixed - Bad ball joint
Old Jul 17, 2007 | 11:19 PM
dblair's Avatar
For some time, I have had front end clunking noises when going over bumps (especially when hitting bumps while making a left hand turn) . Also, the streering/handling didn't seem to be as tight as it once was. I had a mechanic look at it a couple of times but they were never able to find any looseness in any of the streering/suspension components...none of the components seemed to have any play with everything attached. The noise seemed to come from the right front, so I removed the right side control arm to inspect. The sway bar end link was good (it been replaced recently) and the inner and outer tie rods seemed OK. The sway bar bushing had also been replaced recently and was still good. I found that the ball joint however was very worn and sloppy. So, I got a new control arm with ball joint and put it all back together. The noise is gone now and the handling feels tight again. I'm surprised at how that bad ball joint could not be diagnosed while it was attached. This writeup for the LCA replacement procedure was very helpful: http://forums.maxima.org/showthread....&highlight=LCA
I did not have an impact wrench to get the hub nut off, so instead I bought a 36 mm socket with 3/4 in drive and a long 3/4 in drive breaker bar. To break it loose, I left the wheel on and just popped the center cap off the wheel...my 36 mm socket just fit through the center cap hole. Breaking the hub nut loose was no problem at all like that.
Old Jul 18, 2007 | 05:56 AM
dralucard's Avatar
Did you get an OE arm? How would you rate this install on a scale of 1(easy) to 10(hard)?
Old Jul 18, 2007 | 09:25 PM
dblair's Avatar
No, it's not OEM...it's an aftermarket arm that I bought on ebay. I would rate the difficulty maybe around 6. It's not overly difficult, but you need good strong tools with lots of leverage because the hub nut is highly torqued and those nuts and bolts on the control arm both highly torqued and seized from rust. Also, a ball joint separator tool and a tie rod separator tool were required...it cost me under $30 for those two tools.
Old Jul 19, 2007 | 06:06 AM
dralucard's Avatar
cool, thx.
Old Jul 19, 2007 | 06:14 AM
XJinCT's Avatar
<3's the all motor section
yea the most difficult part is the axle nut without a impact. i did mine without an impact with my 3.5 swap, god what a pain that was.
Old Jul 19, 2007 | 08:49 AM
unclpaule's Avatar
so did you have a problem getting the bushing pin off of the old control arm? from reading several post on here about LCAs it seems like thats a common problem
Old Jul 19, 2007 | 09:07 AM
gary_25848's Avatar
I had a similar issue. struts were under factor recall and were replaced
Old Jul 19, 2007 | 10:15 PM
dblair's Avatar
Nope, once I got some 3/4" drive sockets and a monster 3/4" drive breaker bar, I had no problems getting the hub nut and the bushing pin off...Again, it's all about having tough tools and lots of leverage.
official_style
Aug 29, 2015 10:10 AM
maxocar
Aug 21, 2015 12:57 AM
jhontelj
Aug 17, 2015 04:07 AM
soon2ownmax
Aug 13, 2015 02:19 PM
classymax420
Aug 6, 2015 06:35 PM
