View Poll Results: If you have the front spring popping noise, do you have the sport package?
Sport package
50.00%
Non sport package
50.00%
Voters: 8. You may not vote on this poll
Those with eibachs...
Old Aug 22, 2015 | 07:01 PM
official_style's Avatar
I'm trying to figure out why some cars have the front spring popping issue and some don't. I'm starting to think only sport package cars have the issue. Also, I have had the updated front springs eibach sent me in for a few weeks now, and have no more front end noises while turning the wheels.
Old Aug 23, 2015 | 05:31 AM
Asav's Avatar
SV premium here and i have gotten those noises before on the front passenger side spring. Install is perfect, with the spring seated properly, as I have put springs on a few cars now. I checked every piece of the suspension there down to bushings and retorqued.
I jacked the car up and checked the spring seating too...everything is good. I have some vinyl tubing on the spring to eliminate that possibility and I even lightly greased the "cup" of the rubber insulators top and bottom of each spring to eliminate any issue with the slight popping. Guess what? Still there although only happens randomly every couple of weeks. I have had no actual problems with install on the car itself other than that random noise
If you went this route and it worked, I'm inclined to believe the original design was defective. I will pursue this when I am ready to change struts out down the line.
Old Aug 23, 2015 | 04:44 PM
Dudemaine's Avatar
SV sport/tech on Eibachs with no popping, creaking etc. Springs installed February 2014.
Old Aug 24, 2015 | 08:07 PM
rEVIL's Avatar
Sport pkg. Had popping noise and changed new struts with and bearings but have some popping noise anws, less but did not disappear...
Old Aug 24, 2015 | 09:43 PM
pdub34's Avatar
SV sport 09 no popping noise and had the eibachs for 3 years
Old Aug 25, 2015 | 08:32 AM
scotthac24's Avatar
2011 sport pkg...popping noise started the day i had them put on...eibach is still giving me problems with sending me the linear springs...they say they have to sell out of the progressive ones first
Old Aug 27, 2015 | 08:28 AM
Sir Tilus's Avatar
2010 SV premium package. With all the research and talking to Eibach tech support, the pax side spring just has a design defect...
Old Aug 27, 2015 | 08:29 AM
Sir Tilus's Avatar
Told me the same...
Old Aug 27, 2015 | 11:45 AM
Asav's Avatar
I have to say this makes me look at eibach in a different way. The spring is defective. They know this, yet they still persist to delay making it right for those that have discovered they have a defective spring/set because eibach wants to keep selling the existing manufactured lot of which there will be other defects based on their original design. That's funny to me and very bad business. If a customer tells you they have a defective part that is contributing negatively to their car, which has had the suspension issue thoroughly checked, then the part should be replaced end of story. Especially when your own company acknowledged the design should be modified and was subsequently modified. I wont purchase anything else from them going forward. I had tein springs on the 6th gen and I only got these because options were limited at the time.
Old Aug 29, 2015 | 10:10 AM
cheftoo's Avatar
I bought the Megan racing SV Street series coil over and had them installed this week. So far I have had zero issues. Tight and no sounds. Glad I didn't get Eibach.
ZAKDADDY
May 15, 2012 01:16 PM
koreanmaximan
Jan 18, 2005 11:24 AM
SleeK98se
May 5, 2004 02:23 AM
maximaracer28
Nov 21, 2003 06:36 PM
