20" wheels....offset questions
I have an 05' SL, with a set of 20 x 8.5 wheels on the way w/ Nitto 555 245/35/20.
Will be dropping the car w/ a set of Eibach springs.
Are these wheels going to bolt right on w/ no problems or do I have to do something about the wheel offset? I'm a newbie w/ this stuff so please be patient
If the bolt pattern is correct, they will bolt right on 5x114.3 Also what is the offset of the wheels this will make or break your setup...I am running your same setup with 38mm offset and it tucks nicely...
Originally Posted by KCmaxx
So you bought wheels and are now asking if they are going to fit?
Dee-Dee-Deeeee
Dee-Dee-Deeeee
What the point of your post? How's it supposed to be helpful?
I bought the wheels from an online vendor, told them exactly what kind of car I have what model what year, they matched up the wheel and said they're fine. I'm reading on these boards about people running different offsets and that where my question stems.
Please if you don't have anything helpful to add.....why post??
It all depend on the wheel offset, there is some member that are running 265 in the back without rubbing but they are not running on 20's.
35-38 mm sound like the offset you may want, so 20" x 10" with a drop, it's going to be a close call, the rear fender can be roll to add little more space to tuk in the tire.
Originally Posted by JG1
Yep exactly...isn' that how everyone does it?
Talk about worthless posts...
If you bought them to fit the max why are you here asking if they'll fit?
Whats the backspace? Whats the hub size?
If you have wheel fitment questions check the STICKIES... That's what they're there for.
What have your two post added? Tell me?
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
