These Sounds at Startup Normal?
Hi everyone, I have wondered about the sounds that I hear at startup and make me uneasy sometimes. It just occurred to me now that of anywhere that I could get my questions answered, as I always have for other things... this is the place! Anyway... There are a couple that I wanted to ask about. First, when you first shift into gear (auto) when the car is cold in the morning, do you hear the transmission 'clunk' into gear? It's been like this since we first bought the car (new) in 98. I suppose that it might actually be the brakes, since I know the car jerks forward a bit when I go into gear w/o holding the brake but the clunk is not noticeably there. However, I don't know if it's gotten gradually worse or not since I have gotten it. The sound disappears entirely once the car is warmed, but never fails to appear when cold. Perhaps it's the higher revs (idle) or cold tranny fluid when first started. Also, I have noticed just recently that when I first start, I hear a scratchy high pitch noise from the sides of the car, when moving only. (brakes?) But it is gone once warm also. Maybe it's the brake still on the disk, riding it when cold? and oh yeah, btw, is it ok to bend away the circular looking 'thing' right in the center of the engine bay, under where the strut bar goes (mine touches it)? (I know, very technical explanation, huh?)
98 SE Auto 27500 miles
Thanks everyone!!
or... maybe this all has to do with: http://forums.maxima.org/showthread....threadid=53203
Thanks everyone!!
Originally posted by medicsonic
You probably have the right answers to the first two questions, but what is 'the circle thing'?
Thanks!,
Amit
Is it plastic,kind of a wide oval, and surrounds the throttle cables?
The thing that separates the inside of the car, and the engine (its painted the same color as your car and has a metal plate attached to it). If that is the part you mean (its black and plastic), then that is the thottle cable housing, but the FSTB shouldn't be that far back. The onlyt other thing in the way possibly is the brake fluid resevoir, but that is way over to one side.
Nothing there in my car. Sorry. Anyone else?
I just went out and checked my 96 auto GXE. I have Courtesy's FSTB. I see a black perfectly cirle device, on one side of the FSTB towards the car front, and yes maybe an inch or two closer to driver's side of the car. You know the FSTB and throttle cable forms an angle. That circle device is right in that angle, sitting on a metal bracket. It's not just a flat circle, but two stage circle with the top one smaller. Base circle is about one and half inch and the top circle is maybe 3/4 inch. In my car it's kind of far from touching the FSTB.
Originally posted by iamit
thanks... did you move it out of the way to get it like that? About the noise, if it's the break wear indicators, don't they stay on even once warm then?... is it too early for breaks at 27500?...
My car has 33K miles now. The 30K mile service report said the brake pad has 60% or 70% left, don't remember exatcly how much but is far from needed replacement.
Not at all. I just put FSTB on.
a mechanic put my fstb on... maybe i should check with someone else to make sure that it's on exactly right... i don't really see how to mess it up, but it's definitely touching... and oddly enough... it's the cause of a crunching noise when it rubs the FSTB.
AaronL
Aug 8, 2020 10:31 AM
Need help
23
Oct 2, 2015 08:56 AM
