Do you trust your stock tires?
Old Jul 19, 2001 | 06:26 AM
PhatGuy
What is the speed rating of our Potenzas? Up to what speed do you actually trust the stock Potenzas?
Old Jul 19, 2001 | 07:19 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
I don't trust them.
Old Jul 19, 2001 | 07:40 AM
UMD_MaxSE's Avatar
Got Bent?
in the wet especially, I don't trust them at all...
Old Jul 19, 2001 | 07:45 AM
respect123's Avatar
tires
Yeah the tires do act like crap in the rain.
They are the worst wet tire to put on the max.
Old Jul 19, 2001 | 07:52 AM
Jeff2k1GLE's Avatar
I don't trust them either.. I've had a flat, a blow out on the highway, and a bubble.. and they defintiely do suck in the rain
Old Jul 19, 2001 | 08:12 AM
jjs's Avatar
jjs
Hate them and certainly don't trust them. They feel a bit 'squirrely' at higher speeds and we all know how they suck unless the road is absolutely dry.
Old Jul 19, 2001 | 08:17 AM
Jeff2k1GLE's Avatar
Originally posted by yo_its_ok
I took MPNY members on a ride they'll never forget...on stock tires in the rain... ask them how much fun I had with them.... hard cornering, U turns, Hard braking, peeling down a block, all drifting around like a maniac. Pathmark parking lot became my road course ...I swear if we taped it...it would be an awesome Maxima commercial.
The stockers provided fun. My Toyo Proxes FZ4s provide too much grip....my T1S on Kinesis rims on the track...forget it...I can slide like I did when I had my stockers on. When I expect it to break loose and get ready for counter steer...and I don't feel it ready to break...and I gun it to provoke it a bit, what a wonderful feeling when it finally does, and then the inside wheel finally hits the ground....Thats f***en cornering....
-Dirft King~!
ur an animal!
<--- hogan
when do you leave for cali??
Old Jul 19, 2001 | 08:19 AM
maximawanabee's Avatar
True. I'm cautious of going 60-70 mph in the rain with the stock potenzas and I can easily spin them from a standing stop--and I'm not even pressing the gas that hard.
But if the road is really dry then I'm ok. Cornering with the stock RE92's are a different story.
Old Jul 19, 2001 | 08:26 AM
UMD_MaxSE's Avatar
Got Bent?
Hogan is right..... the slip sliding action the potenzas provide can be fun also.
Old Jul 19, 2001 | 08:33 AM
bert's Avatar
In the dry they are not too bad. In the wet they are (choose one of: fun, scary). In the wet it's just too much fun to parking-brake a u-turn.
While automatics may be pegged at 133, Manuals can do 140-141. That is when the drag limit hits. I had it up there a few times and everything is rock solid.
They seem to stand up to abuse very well.
Old Jul 19, 2001 | 08:44 AM
max2001se's Avatar
Only when the road is bone dry...
and I am going in a straight line or taking gentle twisties.
When wet forget it, took a left turn at light the other day in the wet, was going about 15mph (to try and make the light) could feel the the car slide. Not fun. So now in the wet I am real gentle (and slow)with the car.
Old Jul 19, 2001 | 09:04 AM
Ironlord's Avatar
I like my Toyo Proxes A05's. Best stock tires I've seen on any cars I've ever driven. But, then again, I haven't taken the car past 8/10ths. We'll see.
Old Jul 19, 2001 | 11:02 AM
PhatGuy
So if lowering the car on H&R's would that allow for a little bit better top end? Assume 5spd top end is 140? Flipmode_cali mentioined he hit 145 and he is on H&R?
Old Jul 19, 2001 | 11:09 AM
2001SE's Avatar
I had once a tear on the side...those potenzas cost me 240 to replace with labor...
Old Jul 19, 2001 | 12:08 PM
PhatGuy
So if the car is lowered it will help out on top end? Does anyone know what the top speed of a 5spd 2K+ is at 6700rpm?
I had to disconnect my speedo cable, and hook up a temp tach since I lost all dash useage.
My friend in his Supra ran next to me...and as I accelerated he would stay behind me and radio in speed in 10mph increments...I was passing 140, and hit 150, then saw a sign we use to let go and cruise down....My rpms strained near redline, and as my rpms got near 6200rpm I see my A/F Ratio gauge showing a lean out("rean" for those w/ Tomei A/F gauge.)
Be sure not to run any accessories while doing this. Your alternator does not know how much to recharge your battery. I was running my radio before, and listening to music loud and when i slowed down, and shut off the car, the car wouldn't start, so I too precautions now.
I think the Apex Rev/Speed Meter can bypass the speed limiter, but I'm not too certain.
-Peace
Old Jul 19, 2001 | 12:49 PM
LoveSick's Avatar
The BridgeStone high performance Potenza RE92 is more than just tire! It's an adventure!
Old Jul 19, 2001 | 04:07 PM
RussMaxManiac
I have hit 145 with them, but I do not recommend pushing them at that speed for a long period, I doubt they will take it at there limit for a very long period of time.
Old Jul 19, 2001 | 04:08 PM
RussMaxManiac
In my last post, I hit 145 a few times, car was still pulling, could probably hit 150+ but I am not that crazy.
Old Jul 19, 2001 | 05:08 PM
2001SE's Avatar
What is the difference between 145 and 150,155...5 miles per hour...hehe that's nothing but if you are affraid from the tires then you are right...its very dangours at those speeds...if one of em gets blowed its gonna take days to scarp you off the road..LOL
PhatGuy
3 questions in one?
I have 33psi all the way around now
What is the best PSI pressure for launching on the stock tires?
What is the best psi for cornering? I have 33psi now and it squeels like a pig in medium hard cornering. (i have a fstb/rsb as well).
What is the best PSI for highway driving?
So I guess the question really is what is the best over all PSI for front/rear on our stock tires?
Old Jul 19, 2001 | 05:19 PM
y2kse's Avatar
I'm OK with the stock Potenzas for now. Based on what I've read in this post and other posts like it, I NEVER push them in wet weather. Of course, living in Los Angeles helps a lot.
My problem is figuring out what I'm going to do when it comes time to replace the Potenzas. I'd like to keep my stock SE rims, but that seriously limits my choices. I like the looks of the Nitto 450s but I hear they suck big time. So I may have to opt for the Michelin Pilot XGT Z4s at $182 per tire.
It wouldn't cost that much more to pick up a set of inexpensive or used 17 x 7.5" rims and buy some Kumho Ecstas in 245/45R17 instead. I guess I'll make that decision when the time comes.
Old Jul 19, 2001 | 05:20 PM
2001SE's Avatar
Re: 3 questions in one?
1. madmax2k launched his auto with 20psi and got 14.38(i think)
2.As the psi is low you have more traction but more drag(lower speed,more fuel is required,the car feels softer on the road and not good for the tire) more psi...less traction,less fuel,better for the tire,road feels harder)
3.For highway the best psi is the high psi...you don't need traction,less fuel,there are no bumps so the road feels good)
The overall the Nissan recommends is 32 all around...i heard a lot putting 33,i put 32, but on my last car they told me 32 at front, and 26 at back so you can play with that...but i think 33 is good for everything
Old Jul 19, 2001 | 05:57 PM
bert's Avatar
5 or 10 miles... Einstein said somthing about .5M*v^2
5 miles makes a diff at that speed.
The highest I got mine was 141 with 2 other 200 pund guys in my car. I capped at 141 @6100 RPM, certainly it had 300-500 RPM before bouncing off the limiter. So, 145 is certainly not out of the question given the right conditions.
Old Jul 20, 2001 | 01:02 AM
irvine78's Avatar
Re: tires
want rain tires? try the Nitto 555s...
Old Jul 20, 2001 | 03:21 AM
javamax's Avatar
Potenza RE92's
No... I keep nursing mine, hoping someone will come out with a reasonably priced, high quality, stock size tire. Otherwise, I plan to buck up for Michelins. BTW, Bridgestone must have a great salesperson somewhere - I saw a new WRX with RE92's as well. I have know idea why manufacturers are putting such a lame tire on great cars like the Max.
9aj9
Apr 5, 2020 12:11 AM
BkGreen97
Apr 2, 2016 05:47 AM
cruce91
Sep 20, 2015 10:23 AM
jfl330
Sep 4, 2015 01:44 PM
