98 Maxima rear brake
I am looking for a step by step for changing rear rotors for my max.
I watched somebody changing his front brakes on a non-Maxima, and he said that changing/servincing the rear pads and calipers is a little different as a special tool is require to release the caliper.
Is this true? and there is a step by stepper "how-to" with pictures, for the rears?
For those looking for the fronts here is the excellent link:
http://www.motorvate.ca/mvp.php/302
you need to turn the piston in order for there to be room room for the new pads. This can be done using a pair of needlenose pliers. Or you can do it the correct way and go to autozone and buy the piston ratchet extension. It lookslike a box kindof. it's only about $9 and will make the job much easier.
Now the Haines manual which I already own points out on 1995 and later maximas there is a retaining spring over the pads. I see none on front and rear.
No sweat?
Am changing regardless as outside below min thickness but the outside pad does have two tiny vertical fractures. So whether used or almost new, if so change without question, right?
No sweat?
One small thing, but the stupidest question is the one you never ask.
I changed the front brake pads. On the second wheel I noticed one pin, the bottom one was different than the other. It was ribbed at the end. I prompting put this one back in the lower spot.
But the first wheel, I didn't check the pins. Any harm is the "ribbed" is in the upper spot?
Just being safe.
Just being safe.
Huttig2009
Sep 25, 2015 03:31 PM
Maxilano
Aug 31, 2015 07:33 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
RealityCheck
Aug 5, 2015 06:18 AM
