Foglight Restoration Pics - Before Plastx, After Plastx, and After Sanding and Plastx
I swapped out my fog bulbs with Silverstars to match my headlights, so I figured it would be a good time to clean up the lenses. After reading flxsunxchick's post, I went out and grabbed some Meguiar's Plastx and gave it a whirl.
Straight from the car, nothing applied(Left), 3 Coats of Plastx(Right)
Close up of left
Close up of Right
Close up of left
Close up of Right
As you can see, the Plastx had only a minimal effect. Wasn't satisfied, so moved on to sanding. Used 400, 800, 1500, 2000 paper and soapy water. I skipped out on the 600 bc I couldn't find it, and didn't use 1000 bc I forogt it and was too lazy to go back out.
Some pics after each sanding stage:
400
800
1500
2000
400
800
1500
2000
Then applied 3 coats of Plastx using a foam applicator and a terry cloth to wipe clean and buff.
Right Side After Sanding + Plastx, Left Side Untouched
Close-up
Both Lenses After Plastx Application (Left side looks a little dull do to the lighting)
Close-up
Close-up of Left side
Close-up of Right side
All in all, I'm extremely happy with the results. These foglights were pretty bad with a lot of pits and besides one or two small specks, they are pretty much flawless. They should look great with the Silverstars once I get them installed again.
Im definitely doing my headlights this weekend, but I'm wondering, can I wetsand and Plastx the side portion of the headlight (where the blinker is)? I noticed that this isnt flat like the rest of the lens.
Wow! Nice job. I was using scratchX for my headlights. I picked up some plasicX today. Ill have to use it, didnt get nearly the results.
I dont know about your blinker. By not flat, you mean rough? Im sure someone will chime in.
Originally Posted by VIP Maxima
5th gen fogs are plastic? i thought they were glass
has anyone done the inside of the lend?? headlights for example get some film of some sort on the inside (i think) kinda light yellowish color, ill be sanding mine down soon but just wondering
good job !!!
good job !!!
lucky. 4th gens are glass and we cant sand em
Originally Posted by GigEmAgs07
any particular pattern to your sanding?
Originally Posted by badboi4eva
Wow. I would like to do the same but I went to home depots today but couldn't find 400, 800, 1500, 2000 ones. xD Where can i get 400, 800, 1500, 2000 ones? thanks.
Originally Posted by 2 MaXiMuS 4
^^just the outside. If you think about it, how could it get that dirty from the inside if the assembly is completely sealed?
Apr 16, 2020 05:15 AM
bigfrank
Oct 1, 2015 12:51 PM
