FS: 95 Max, parts car, blown engine - $500
Old Aug 5, 2007 | 10:47 PM
Leroy111's Avatar
170,666 Miles, Auto tranny with 100,000 miles on it. Thru a connecting rod thru the block and de sheet caught on fire, sending flames shooting out the rear of the car scorching the rear bumper and rear passenger tail light. Paint in okay shape, little rough around the edges but nothing major, driver's side door molding is cracked and borked.
Interior in good shape, painted dash with LED modified controls. CAI and front strut bar were the only other modifications to the car. Pioneer CD player (button lights not working, but display still in good cond., could just use a new faceplate for full functionality) Pioneer 6.5inch front speakers, Dual (more than likely blown) 6.5inch rear speakers, and a very weak sound sub woofer system in the rear (2-12inch Lightning Audio... 350ish? watt amp)
Car domain for pictures (pre-wreck state) here: http://www.cardomain.com/ride/710667
Wreck story here w/ pictures:
http://forums.maxima.org/showthread.php?t=530352
car is currently in New Ulm, MN, will need to have some method of towing
Old Aug 9, 2007 | 02:10 AM
Leroy111's Avatar
given'er teh bewt up
Old Aug 9, 2007 | 09:26 AM
black_maxed95's Avatar
throw up some pics of the whole car. sides and front. is the bumper and one tail light the only body damage? INTERESTED!
whats the mod list that is included with the car also
thanks
Old Aug 9, 2007 | 11:54 PM
Leroy111's Avatar
Give me a few days to get these pictures up for you, I am currently in my college hometown.
Mods: Painted dash
Silver Gauges
Shaved trunk, emblems placed on dash interior (krazy glue, don't plan on prying these buggers off)
Stereo system upgrade, 8GA Amp wiring + RCAs (rockford fosgate)
Head unit of stereo could use new faceplate, one on currently is funky
CAI intake (true CAI, goes into fender)
Front strut bar
Wired up for drop resistor mod with WOT switch
Interior blue cold cathode lights
Cut down / changed shift ****
LED windshield washers (switch on center console)
Remote antenna switch on center console as well (Antenna could use greasing/replacement)
New passenger side drive axle, CV joint/boots (only about 3,000 miles on it)
I'll send you a maintenance record along with the pictures.
Old Aug 10, 2007 | 08:47 AM
ok thanks alot
Old Aug 10, 2007 | 04:08 PM
Maxima_Joe's Avatar
4th Gen Parts King
Do you check your email or private messages?
Old Aug 10, 2007 | 08:27 PM
Leroy111's Avatar
pics will be ready Sunday afternoon sometime
Old Aug 10, 2007 | 08:31 PM
Leroy111's Avatar
fanaticrockford has dibs at this point in time depending on whether or not car is in decent enough shape for him (he sent a pm about it last week, before post went up, sorry black_max)
Old Aug 10, 2007 | 08:33 PM
......fine fine. try to get me some pics sunday tho incase it falls through.
Old Aug 12, 2007 | 07:04 AM
Leroy111's Avatar
http://s52.photobucket.com/albums/g29/Crockpot1/
Pics ^^^
Problems that I forgot to mention: >.<
  • Front passenger fender has a large dent in it, will probably need a replacement (note that it actually doesn't look all that bad in person from an aerial shot)
  • Rear passenger wheel well had rust problems, I took a dremel to it and cleared most of it out, covered it in red primer, though I did manage to **** up part of that rear door, like a monkey
  • Clock hour button doesn't work
  • Tachometer likes to stick, mainly because of rubbing on the aftermarket indiglo gauges (fix: pull gauges and sand the bottom black portion of the needle, making it able to clear the gauge surface)
  • Radio headunit needs new faceplate
  • Check engine light, rear O2 sensor out, however car will include a front O2 sensor (ordered wrong one $70ish dollar value)
  • Antenna mast needs re-greasing/replacing
  • Parking brake cable sticks, needs work
Tires have 20,000 miles on 'em
Old Aug 12, 2007 | 09:05 AM
Leroy111's Avatar
Maintenance Record
Date Fix Milage
4/20/2007 Oil/Filter 169,000
2/18/2007 Oil/Filter 162,900
9/18/2006 Oil/Filter 166,000
2/25/2006 Oil/Filter 160,310
7/22/2005 Oil/Filter 157,129
5/5/2005 Oil/Filter IAC valve cleaned 156,000
4/20/2005 Used Transmission installed - Appx 70,000 miles on it 155,500
4/5/2005 Knock Sensor - Coolent drain/flush 155,000
2/1/2005 Oil/Filter - Shifter - Painted dash 154,850
1/17/2005 4 Tires - Rear pads/rotors 154,500
8/3/2004 Oil/Filter - Spark plugs 152,148
4/11/2004 Oil/Filter - Fuel filter 150,725
10/2/2003 Oil/Filter - Stereo 148,255
5/17/2003 Oil/Filter 145,931
2/1/2003 Topped Fluids 142,925
Change of owners
11/12/2002 2 Tires 141,000
10/24/2002 LF Boot/Axle shaft 140,500
8/27/2002 Driver's side power window motor 140,000
5/10/2002 Oil/Filter 135,500
2/5/2002 Injector 134,000
1/14/2002 Fuel Filter 133,500
11/24/2001 Headlight 133,000
11/12/2001 Lube/Oil/Filter - Transmission Flush, Front brakes 132,500
8/1/2001 Oil/Filter 128,500
4/30/2001 Oil/Filter 125,500
12/20/2000 Oil/Filter 122,500
9/11/2000 Headlight 120,000
9/6/2000 Oil/Filter 119,000
6/29/2000 Oil/Filter 115,000
3/27/2000 Oil/Filter 113,000
10/26/1999 Oil/Filter 109,500
8/5/1999 Oil/Filter 106,000
5/6/1999 Oil/Filter 102,000
2/16/1999 Oil/Filter 99,000
12/22/1998 Fuel hose/clamp 95,500
12/10/1998 Oil/Filter 94,000
11/15/1998 Battery 93,000
10/5/1998 Oil/Filter 90,000
7/31/1998 Oil/Filter 84,866
5/8/1998 Oil/Filter 79,000
2/14/1998 Oil/Filter 74,000
1/30/1998 Starter 73,000
12/13/1997 Brakes 69,000
10/7/1997 Oil/Filter 64,000
8/1/1997 Oil/Filter 59,000
6/2/1997 Transmission Fluid - Coolant Flush, Drive Belts, Fuel Filter 55,000
5/21/1997 Oil/Filter 53,500
3/9/1997 Oil/Filter 49,000
2/24/1997 Antenna Assembly & Mast 48,700
12/28/1996 Oil/Filter 43,000
10/26/1996 Air Filter 40,000
7/31/1996 Balance 39,000
7/8/1996 Injector & O-Rings 32,600
5/16/1996 Alignment, Fuel & Air Filters 28,750
5/4/1996 Oil/Filter 28,100
2/13/1996 Oil/Filter 24,500
10/24/1995 Oil/Filter 20,750
8/7/1995 Oil/Filter - Air filter, Fuel Filter 17,000
7/3/1995 Injector & O-Rings 16,000
5/27/1995 Oil/Filter 15,300
3/7/1995 Oil/Filter 11,500
11/7/1994 Oil/Filter 7,500
8/3/1994 Oil/Filter 3,000
Old Aug 12, 2007 | 01:40 PM
Maxima_Joe's Avatar
4th Gen Parts King
Let me know a # where to contact you.
Old Aug 13, 2007 | 01:06 AM
Maxima_Joe's Avatar
4th Gen Parts King
I'll call you some time Monday. Everything looks good though.
Old Aug 13, 2007 | 01:33 AM
Leroy111's Avatar
u can call me now if you're up, I'll be up all night, 3am on, til late monday night
Edit: f***, forgot my phone at home, contact me on MSN: lee.windschitl@mnsu.edu or AIM: lee0windschitl
Old Aug 13, 2007 | 05:12 AM
Leroy111's Avatar
car considered sold, honestly sorry for you black max, better luck next time
Lakersallday24
Jun 16, 2019 01:35 AM
YourLocalAsian
Aug 17, 2015 02:33 PM
Balkins
Aug 12, 2015 06:39 AM
