MIL trouble codes... please HELP ! ! ! !
Old Aug 7, 2007 | 04:49 PM
y0_nate's Avatar
Yeah so my check engine light decided to come on with the following trouble codes
p1148-closed loop bank 1
p1168-closed loop bank 2
p1031-Air/Fuel Ratio Sensor Meter
p1051-Air/Fuel Sensor Heater
Guys I'm completely clueless ..... I tried to read about the common problem and it seems that this stuff was written in Nissan language because I'm dumbfounded.....
Here is the link: http://www.nissanhelp.com/Ownership/.../NTB04-024.htm
I have an appt with the stealership tomorrow and I want to be prepared on what they "think" they are going to tell me.
ps: I didnt opt for the extended warrenty and now I'm paying for it
Any information would be GREATLY appreciated !!!!!
Thanks!
Old Aug 7, 2007 | 04:51 PM
mtrai760's Avatar
'Trynna' is not a word
Seems pretty clear that you have a problem with one or more of your O2 sensor.
Old Aug 7, 2007 | 04:54 PM
y0_nate's Avatar
which is what I figured...... but I changed both o2 sensors before the cat last week and still come up with these codes...... so then im guess its the both after the cat?
Old Aug 7, 2007 | 04:57 PM
mtrai760's Avatar
Could be, but I would do some more research before you spend anymore money on O2 sensors. I don't have a service manual available for a 6th gen, but it should tell you based on your codes exactly what sensor is bad. You may also just have a wiring problem.
Old Aug 7, 2007 | 05:03 PM
y0_nate's Avatar
true that........ i ordered the CD version of the OEM repair manuel which actually came in today..... hopefully I can find out the problem and take care of it myself......
thanks for the input bro
-nate
Old Aug 7, 2007 | 05:13 PM
NmexMAX's Avatar
dot dot dot ...
Hmm, you can find it here too. But yes, seems as if 3 of your 4 O2 sensors are mad for some reason.
http://www.vq35de.com/ESM/Nissan/
Old Aug 17, 2007 | 09:12 PM
Smoke_Screen's Avatar
sorry for the n00b question, but my engine light's been on for about a week and I was wondering how you get the code? Do you need a laptop and special software?
When I first start the car the AT light comes on for a second, then goes off so I am tending to thing it's related but...
Old Aug 18, 2007 | 12:50 AM
Fastmax05's Avatar
"Ok,Whats next?!?!"
You need to get an obdII reader... buy it from pepboys/kragen/auto zone... think they are like 65-90 bucks if i remember right? guys?
OR you can bribe one of hte guys that work there into checking it for you, but pay him on the side... works here in cali ??? haha
Good luck friend..
Old Aug 19, 2007 | 05:32 PM
jreilly04's Avatar
P1148 - Bank one does not operate in closed loop
P1168 - bank 2 does not operate in closed loop
Both possible causes are harness and or connectors are shorted or open or a/f sensor or a/f heater is bad.
P1031 - A/F heater control circut too low.....current amperage in A/F heater is out of normal range. same possible causes as above.
P1051 - Same as P1031 except this is bank 2 P1031 is bank one
Old Aug 20, 2007 | 12:25 AM
ramberg's Avatar
GrandPa
Go to Auto Zone. They will check it for you for free.
Old Aug 20, 2007 | 06:35 AM
chernmax's Avatar
Nations 1st 6th Gen Turbo
Good luck friend..
My OBD-II with software cost about $140.00
I'd also consider removing the positive battery terminal for about 30 minutes to clear the codes on your ECU. If you truly have a problem, the codes will come back!!!
Old Aug 20, 2007 | 08:19 AM
madmik's Avatar
Bizarre, as if the O2 sensors are not connected? Has the dealer found something? Bad ground? A melted wire that shorted the circuit?
Curious that both sensors and the MAF would stop working at the same time.
14GmMax
59
Aug 4, 2019 11:26 AM
zmcneely13
Sep 26, 2015 02:26 PM
msellas
Sep 23, 2015 09:16 PM
Socalstillen
Sep 20, 2015 11:46 PM
