Can't seem to remove glove box
I dunno if I'm an idiot or just afraid of bending/twisting things, but I can't seem to figure out how to remove the glove box in my 99 maxima. I have a PDF of the FSM, but it doesn't seem clear how to remove it. I've also searched the forums, but the results all seem to relate to replacing/removing things behind the glove box, as though it is so easy to remove, it doesn't need to be explained. =)
there are 5 or 6 screws in total that need to be removed.
1) look Under (where your legs go) and there will be 2 screws on each side, remove them.
2) then open the glove compartment and there you wll see the latch that the lock hangs on to when closed, the latch is attached by 1 screw if i remember correctly, remove both and there it is,...
3) then there are 2 screws on the edge of the glove box at each side if u open it
be careful: when all screws are removed, the glove box will attept to fall, u must hold it and disconnect the wire that leads to the bulb harness (light inside the glove box). once that is disconnected, its completely out.
If u have more questions PM me for info, but where r u at right now ? whats the ptoblem exactly ?
my03maxima
Jul 28, 2024 07:40 AM
RealityCheck
Oct 2, 2015 06:34 PM
