Attn, ColumbianMax, others that know how to get COLD ac
My AC blows 50-53 degrees in full sun and in the dark of night. My low side pressure is around 20psi. Haynes HVAC manual specifies 18-23psi for my maxima.
If the compressor didn't cycle off it would blow much colder because the temp drops fast while its running. But like clockwork it cycles off when the vent temp is 50.
Does anyone with colder air know their low side pressure? Could there be a sensor in the evaporator that is kicking the compressor off? I noticed some thingy with a wire going into the output side of the evaporator box.
I shall attempt to find out my pressure at work tomorrow. As for getting it cooler, I'm not that advanced YET but will be working on learning new stuff. I'm sure someone with more knowledge than I will contribute shortly. For now, be happy you at least get air cooler than 60 degrees
I just have a cheap gauge from the parts store that can measure low side pressure, so I'm not sure about the high side.
Manual climate controls.
Ambient temp has been around 90, but I keep the car closed up. Cabin humidity sinks as low as 19% I'm really getting into this, bringing my meat thermometer into other people's cars, its becoming an obsession!
And I did insulate the cold line while I was living out west, its kind of ghetto with house pipe insulation wrapped over with insulating foam tape and coated with glue. Its very thick and nasty looking so I'm sure it helps.
I had the windows tinted today, 35% on the sides and 20% on the back window, and OMG, why didn't I do this 9 years ago?! Feels much cooler inside now. But I'm still determined to get 40 degree air coming out of my vents!
Amen to that, as soon as I find out how...I'll work on getting my AC blowing 45 degrees and BELOW
although 47 degrees still gets me pretty cold to where I gotta lower the window or the fan speed.
If you have one sitting around and would like to donate it for a potentially useful mod, that would be sweet
Originally Posted by DanNY
now figure out how that would work with the blower resistor.
i'm sure you can slap on a potentiometer and adjust fan speed that way. crack open your EE books
eliminate the resistor with an adequate potentiometer. not my idea of safe though.
What safety issue are you referring to? Starting a fire due to a high current, or something similar? If the blower is not taken above speed 4 then it should be fine. Isnt it on a fuse anyway?
Mmm... yes... quite so.
I guess the potentiometer could be thermally coupled to that same resistor radiator, but obviously it wouldnt be within reach for easy speed adjustment. There are some possible workarounds for this issue, so all is not lost.
It wouldnt be worthwhile if it wasnt a challenge, I dont know of any car that has a continuously variable blower speed. This idea has been knocking around in the back of my head for a while, but I never evaluated it too seriously until right now.
~Alex
My teacher/friend has a 2000 civic EX fully loaded (yes with 30k miles on it) and it has plenty of options for the fan, I think its got like 6-8 speeds IIRC, I was like "WOW!"
i never claimed to be EE expert nor i play one on TV.
best thing is to do the digital swap so whatever temp you want stays there.
tarun900
19
Dec 20, 2021 06:57 PM
TKHanson
Nov 24, 2018 01:39 AM
<===refrigerant
