Cylinders 1 and 6 not working
Old Aug 1, 2007 | 09:04 AM
cparker5's Avatar
So my mechanic is telling me that Cylinders 1 and 6 are not working. Mechenically he says they are fine but it appears that it is something electrical. He was unable to determine the actual cause of this issue and I am wondering if anyone here can help.
My sympoms are the following.
1. Car shakes when idle or acclerating or going less then 25 miles per hour.
2. Car has hard timne climbing hills.
3. Car runs smooth once at 55-65, though has a hard time getting above GM without getting huge RPMs.
Any ideas?
Old Aug 1, 2007 | 09:10 AM
internetautomar's Avatar
mod or sell?
you've got 2 dead injectors most likely.
very common.
Old Aug 1, 2007 | 09:29 AM
93SCMax's Avatar
98 SE
You didn't mention if you had an SE or GXE. If a GXE, I'd replace the spark plug wires, rotor and cap. You can check the resistance of the current wires first, but if your mechanic says it's electrical, I'd check/replace these first.
Old Aug 1, 2007 | 10:36 AM
mikekantor's Avatar
Originally Posted by 93SCMax
You didn't mention if you had an SE or GXE. If a GXE, I'd replace the spark plug wires, rotor and cap. You can the check resistance of the current wires first, but if your mechanic says it's electrical, I'd check/replace these first.
Needs to supply year in addition to SE/GXE.
But yeah like above, probably injectors, maybe coils if it is a VE, sometimes its both.
Old Aug 1, 2007 | 10:48 AM
Jeff92se's Avatar
I'm needing a caw
No spark? Or no fuel?
Old Aug 1, 2007 | 04:44 PM
Tquick's Avatar
Check those cylinders for spark. If it's getting spark, then it's probably injectors. If there isn't spark, check wires, cap, rotor.
Old Aug 5, 2007 | 03:21 PM
cparker5's Avatar
This is a 1992 SE ***
*** The engine type in the owners manual says it is a VE30DE which Wikipedia says is an SE Link: http://en.wikipedia.org/wiki/Nissan_VE_engine
They are getting a spark
Is it easy to change the fuel injectors? Is there somewhere online to show how this is done and what the prep is?
Old Aug 5, 2007 | 08:04 PM
whitemax89's Avatar
i got my bet on a fuel injectors cause i had same problem i changed 5 of them (month back changed 1 so thats y i changed 5 recent)
Old Aug 6, 2007 | 06:08 AM
mod or sell?
it's pretty easy to do if you have patience.
some of them can be done in 15 minutes.
some take longer because you need to pull the intake plenum.
I do suggest doing all 6 new, but if budget is tight and it's only a rear 1, do all 3 rears. saves time later. the fronts can be done 1 at a time.
just don't buy remans/rebuilt/cleaned injectors.
Old Aug 6, 2007 | 06:54 AM
NismoChi's Avatar
Hey Brian, you forgot to tell him where he can buy new injectors from.
BTW, you'll be getting PM from me soon for the same issue.
Old Aug 6, 2007 | 10:41 AM
cparker5's Avatar
I saw some at autozone.com
Gp-Sorensen / Fuel Injector for a 1992 Nissan/Datsun Maxima SE
Part Number: 800-1149N
Weight: 0.2 lbs.
Warranty: 1 YR
Note: New
O.E.M. #16600-96E00
Price: $74
Beck Arnley / Fuel Injector for a 1992 Nissan/Datsun Maxima SE
Part Number: 155-0091
Weight: 0.2 lbs.
Warranty: 3 MO
Price: $68
SHould I replace the orings to for $10 per injector, or not?
Old Aug 6, 2007 | 10:49 AM
mod or sell?
1. I am wary of anything from Autozone.
2. yes you should definately replace the o'rings at the same time.
Old Aug 6, 2007 | 11:04 AM
cparker5's Avatar
The only reason I selected AutoZone is that my experience has been if it is not in fact the injectors I could take the part back to the store. IF not AutoZone, why and what is your recommendation?
Old Aug 6, 2007 | 12:23 PM
mod or sell?
I don't like autozone, I have found that their parts are very substandard in most cases.
for a local place, I'd suggest a NAPA, or a "Corning" auto parts.
Find a smallish local place they will usually have the most knowledgeable parts people, and will try harder to find the part.
Old Aug 8, 2007 | 01:04 PM
trunks333's Avatar
I have the same problem with cylinder 1. I unplugged the spark plug wire from the distributor saw a spark, and did not see a drop in engine speed. So i guess its the fuel injector. But the problem is, while waiting for the new fuel injector that i bought online, the engine fixed itself for a day and was working perfectly. Then the next day, same problem. I'm guessing it was a sticking injector. Anyone know if its possible that an injector can repair itself one day and break the other???? This happened this whole week, one day it runs great, next day runs like crap. Thanks
Old Aug 8, 2007 | 01:16 PM
Greeny's Avatar
¯\(°_o)/¯
Yes,normally injectors do intermittently go "in-n-out" for a while before they finally die all together..
Old Aug 8, 2007 | 01:45 PM
cparker5's Avatar
Te price for an injector at NAPA is twice as much as AutoZone. Is AutoZone that bad where it is worth paying twice the price for new parts?
Old Aug 8, 2007 | 05:32 PM
mod or sell?
on some items yes.
the injector it's a tough call because i don't know what brand is in the box.
Old Aug 13, 2007 | 08:56 PM
Machine's Avatar
Why? Just wondering for my own edification...
Old Aug 14, 2007 | 06:26 AM
Prophecy99's Avatar
very common
I had 2 injectors recently go on mine,
i heard once that cars and especially older ones dont like the ethanol in gas
Old Aug 14, 2007 | 09:28 AM
mod or sell?
because our injectors fail electrically, not by clogging up normally. injectors aren't electrically rebuilt, they are just cleaned out.
so even though the rebuilder tested them, they still fail a bit later on electrically.
I replaced 5 injectors 7 times on my first VE. the last 3 were brand new.
Old Aug 16, 2007 | 12:40 PM
Rodrv6's Avatar
Before you go through the trouble and expense of replacing a dead injector, make sure that the electrical contacts are clean. My 92 GXE (VG) lost a cylinder intermittently (would run bad for a while, then great for a while randomly) and the contacts for that injector needed cleaning. A little time with a small strip of sandpaper wrapped around the end of a small screwdriver and all is well now.
jerrod99_se-l
Aug 27, 2015 08:27 PM
FlaMark
Aug 21, 2015 11:06 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
vanebecker
Aug 17, 2015 08:24 PM
kenc15
Aug 5, 2015 08:29 AM
