Car Wont Start
Car Wont Start
After changing the blown motor in my 95 auto, the darn thing wont start. It just keeps crankin. We tested that it does have spark I can hear the fuel pump and I think all the connections are hooked up. We have also changed both the crank sensors and the cam sensors. any ideas??
you have the 'fastest thunderbird in maryland' and you cant get a maxima started?
well hearing the fuel pump may not be sufficent, it could be flowing 10psi of fuel pressure into the system and it will not start. how did you test for spark? i would check at each coil. also thinking your connections are good isnt sufficent. double check them all. pull any codes that may be present in the ecm. check for compression. are you sure you set timing right?
basically everything im asking you would be the procedure for any engine no-start.
I not by any means a mechanic. My t-bird which I sold now was built by my mechanic. I did change the engine trans in the max but i just read the haynes manual, nothing special. The code that was in the computer was the crank reference sensor changed that. I didn set the timing at all though. I literally just put it back together filled it with fluid and tried to crank it.
Bad sensor
Bad sensor harness
Inconsistent cranking speeds due to insufficient starter ground (aka dirty block/bellhousing mating surfaces)
There might be others but those are the ones that count.
Originally Posted by nismology
That code can come up due to:
Bad sensor
Bad sensor harness
No worries there. There was no timing to "set" in the first place.
Bad sensor
Bad sensor harness
I didnt clean the bell housing to motor surfaces I know for a fact. I dont have the 02s hooked up beacuse my exhaust is not either. and there is a plug on the rear left (section nearest the block) of the trans that has not been connected yet. could those be reasons
Any codes? Was the block surface that mates to the transmission bellhousing clean upon installation?
Im starting to wonder about the fuel pump myself. Its got spark. I checked it on one cylinder though.
He had a 0407 code. But sho-off told me that the code was there before the last engine locked up. We have replaced both crank position sensors (REF and POS) and the cam position sensor.
I had to spray WD40 down inside the cylinders because the engine would stop turning after one rotation (we were installing the converter bolts). We pulled the plugs to see if they were flooded. Heh, flooded with WD40 (dont worry, we didnt hydro-lock the engine). I told him to buy new plugs just in case. That didnt work either...
I heard the fuel pump prime, put couldnt hear whether or not it was running while we were cranking the engine. I will hook up my gauge and check the fuel pressure.
Originally Posted by jaydubb
Nope. Does is really make that much of a difference or is that a Nissan thing?
Try running a wire from the frame to the starter with a ring terminal on both ends and run a starter mounting bolt bolt through it.
Thanks for the tip but it cranks fine. It just wont fire up. It has spark, but I dont think it has fuel. But your idea just make me think of something. I can still use that ground...
Hey...
You ignored the most important part of my post.
I didnt do ANY of the work on THIS car. Everything was done by sho-off. Im not really familiar with Nissans. Its not like Chevys and Fords where you ground at the block (iron in most cases) and thats it. I keep forgetting that the foreign car makers like to use aluminum blocks and such. Now that I think about it, the 4.6 Fords act like CRAP if the grounds arent "perfect". Those are aluminum also. So are the LS1, LS2, LS6 and the LS7. Hope I didnt lose you with all of the engine codes.
So... me saying that I can still use that ground meant that I can still use it to provide a better ground path than what it already has.
Not really sure what the VQ being aluminum has to do with anything as iron and aluminum are both excellent conductors. And I don't know of any modern OBD-II vehicle that doesn't get finicky when the grounds are poor. The injectors need to be grounded, the ignition coils need to be grounded, all the sensors as well, etc.
Either way, the starter ground has has no bearing on how the car runs once it starts so that's that.
Seriously?
Do yall want me to come up there and dazzle you with my infinite A32 wisdom?
Err...yea. If yall want a hand or someone else to **** around poking and prodding various things in the engine bay while acting like a typical hick, I'm your man. Sometimes I get lucky, just takes a fresh pair of eyes...
yea that would be fine
Wassup man!
I will holla at sho-off and see. Maybe then you can pick up that hoist.
EDIT: Give me a date/time/addy, I'll try to be there.
Clogged injectors due to sitting around for a while is not an uncommon occurance either in my experience. Checked each cylinder for fuel?
this sat 12pm does that work
Yea, I don't have to go down this weekend, so I'm free to come up there. Send me the address later. Turns out I won't need the hoist either, my VQ fixed itself
No more BHG symptoms; no bubbling coolant, coolant loss, overheating, etc...hell, I don't know, but I'm sure not complaining. Now a new MAF and I'm good...
Thanx merlin and paul for coming down and helping out.
So know the problem is that the fuel pump primes the line but when we caranked it there was no fuel coming through the line. WTF. We replaced the fuel pump and took of the filter so thats not the problem.
You sure the line isn't kinked in the fuel tank? You sure it's still attached to the barb on the level sending unit? I've had the hose pop off of that barb on me. Don't ask how........
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Maxboy23
Aug 11, 2015 11:59 AM
